Why use adjustable rocker with a hydraulic cam?
#2131985
08/13/16 03:11 PM
08/13/16 03:11 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
Like the title says - why adjustable rockers with a hydraulic cam?
This question came up recently with some car guys I know. I have used them before in a 340 - but really don't have a good answer.
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
Re: Why use adjustable rocker with a hydraulic cam?
[Re: 19swinger70]
#2131993
08/13/16 03:29 PM
08/13/16 03:29 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I can answer that question! Dealing with that right now on my 383. In order to get reasonable preload, not only did I need custom pushrods, but they needed to be 2 different lengths. Since the pushrods tend to be within 0.005" tolerance of each other, I optimized the lengths and now have preload of 0.035" to 0.044" = right where I wanted to be.
Real pain and if I had adjustable rockers you just turn the adjuster screw instead of 2 different length pushrods.
[Re: 19swinger70]
#2132059
08/13/16 04:32 PM
08/13/16 04:32 PM
19swinger70
Richmond, Indiana
Preload seems legit. I was thinking that people ditched stamped rockers because they weren't a true 1.5 ratio- but that's just a guess.0
[Re: 19swinger70]
#2132149
08/13/16 07:06 PM
08/13/16 07:06 PM
Posts: 2,405 Lee Co. Fla.
5carguy
Lee Co. Fla.
Preload seems legit. I was thinking that people ditched stamped rockers because they weren't a true 1.5 ratio- but that's just a guess.0 I have heard this too.
[Re: 19swinger70]
#2132181
08/13/16 07:59 PM
08/13/16 07:59 PM
Posts: 18,157 Mass
DAYCLONA
Mass
This question came up recently with some car guys I know. I have used them before in a 340 - but really don't have a good answer. I run adjustable roller rockers on all my toys, smblk and Bblk RB, I like the 1.6 ratio arms, usually Crane or Isky, plus I run anti pump up hyd. lifters on all the motors as well, so I need the adjustabilty factor, plus the 1.6 is good for up to another .050 lift on the cam with out getting the additional duration
[Re: 19swinger70]
#2132241
08/13/16 09:32 PM
08/13/16 09:32 PM
RapidRobert
why adjustable rockers with a hydraulic cam? mainly for preload #2 wipe pattern 3rd is pushrod angle at adjuster cup
[Re: 19swinger70]
#2132262
08/13/16 10:10 PM
08/13/16 10:10 PM
19swinger70
Richmond, Indiana
Does the preload become more important with a larger, more aggressive cam? Just curious why most stock engines had non adjustable rockers.
[Re: 19swinger70]
#2132297
08/13/16 10:46 PM
08/13/16 10:46 PM
19swinger70
Richmond, Indiana
Are ductile iron adjustable rockers ok for a 500 horse street 440?
[Re: 383man]
#2133463
08/15/16 12:56 PM
08/15/16 12:56 PM
Posts: 114 Oregon
Wagonman1967
Also if you run a decked block and or milled heads it changes the lifter preload so they are nice to have to set preload as was said. Ron Plus custom push rods to keep it all happy.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: markz528]
#2133508
08/15/16 01:55 PM
08/15/16 01:55 PM
Posts: 75,070 U.S.S.A.
JohnRR
U.S.S.A.
Real pain and if I had adjustable rockers you just turn the adjuster screw instead of 2 different length pushrods. The last 2 hyd. cam builds I did I went with adjustable pushrods, I got the exact amount of preload I wanted on every lifter.
