Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2131188
08/12/16 03:25 PM
08/12/16 03:25 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
According to E-booger the factory align-bored cam bearings after installation.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2131193
08/12/16 03:29 PM
08/12/16 03:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted By mopar dave
ok, I checked the cam for straightness. looks like .0005-.001 out. I scraped the bearings with a sharp pocket knife and blended with scotch brite pad. spins good now without binding, but is a snug fit.
You really have a hard on for the scotch brite pad , its not something that should be used on an assembled motor , nevermind a bearing ...
What do you mean by it spins good ? Put a gear on it and spin it , does it stop immediate is you try to spin it fast and let go or does it do a revolution or 2 ? If it stops you still have high spots ... more scotch brite ...
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2131195
08/12/16 03:29 PM
08/12/16 03:29 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
what do you mean by it spins good ? Put a gear on it and spin it , does it stop immeadiate is you try to spin it fast and let go or does it do a revolution or 2 ? If it stops you still have high spots ... more scotch brite ...
Re: fitting a cam into a fresh 400 block [Re: JohnRR] #2131208
08/12/16 03:47 PM
08/12/16 03:47 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I put oil on the pad and it contains the grit to the bearing. just whip of. don't take much rubbing to blend. if I spin the cam it will not continue to spin half a dozen revs on its own. the 20/50 I put on the jounals drags it down.
Re: fitting a cam into a fresh 400 block [Re: John_Kunkel] #2131355
08/12/16 07:17 PM
08/12/16 07:17 PM
According to my old machinest you can't align hone the cam tunnel on any modern day(1951 to current production as of 2003) Mopar V8 due to the tunnel has five diofferent sizes, just like the cam journals have work Maybe Ebooger thought they honed them after installing the bearings on the blocks that the cam would stick in work
It never ceases amaze me to hear urban myths repeated over the internet, supposidily from a relaiblle source whistling work
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2131784
08/13/16 07:41 AM
08/13/16 07:41 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Why wouldn't the factory simply have a hone with 5 different diameters on one solid honing bar?
Or maybe they also just used a stock camshaft with grooves cut into them for quick clearancing... wink
Re: fitting a cam into a fresh 400 block [Re: BigBlockMopar] #2131859
08/13/16 11:56 AM
08/13/16 11:56 AM
Mt Morris Michigan
Mt Morris Michigan
odd thing is the front and rear bearing were showing shiny spots that needed clearancing while sitting on the tailgate of my truck. once on the engine stand only the front bearing was an issue. all is well now as it fits like it should.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2131922
08/13/16 01:49 PM
08/13/16 01:49 PM
So installing the engine stand bolts and putting the block on the stand letting it hang of of the bolts deformed the back of the block enough to affect the rear cam bearing hole shock work shruggy grin
Many opportunitys in life to learn up
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2131947
08/13/16 02:18 PM
08/13/16 02:18 PM
Mt Morris Michigan
Mt Morris Michigan
yeah, I cant hardly believe that would make any difference. whatever, cam has no binding and spins freely. I happy with it.
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2132075
08/13/16 05:03 PM
08/13/16 05:03 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Sure you can, just use a boring tool with five different cutter diameters. Don't confuse align-boring with align-honing.
Re: fitting a cam into a fresh 400 block [Re: John_Kunkel] #2132470
08/14/16 03:01 AM
08/14/16 03:01 AM
He used a Sunnen CK10 for both align boring and alin honing as well as cylinder honing shruggy
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2132503
08/14/16 05:48 AM
08/14/16 05:48 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Most any shop that installs many BB Mopar cam bearings will have a "cutter cam" like the one shown above. Nearly impossible to get them in and not have a tight spot somewhere. Common problem. I also agree with the others. Scotchbrite is not your friend
Re: fitting a cam into a fresh 400 block [Re: Monte_Smith] #2132589
08/14/16 12:22 PM
08/14/16 12:22 PM
Mt Morris Michigan
Mt Morris Michigan
ok, now that I know a pocket knife works good for scraping bearings, theirs no need for scotch brite.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2132591
08/14/16 12:28 PM
08/14/16 12:28 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
As said common issue with bb mopar. Don't sweat it. Ive seen cams that would barely turn with a wrench on the bolt, after some run time it turned like it was on roller bearings. If you only had to massage just one spot on one bearing you got a good block...
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2132675
08/14/16 02:42 PM
08/14/16 02:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never did understand why they made each bearing
size different... my 50mm rollers works just fine
with all of them being one size
wave
Re: fitting a cam into a fresh 400 block [Re: yella71] #2132871
08/14/16 07:59 PM
08/14/16 07:59 PM
Mt Morris Michigan
Mt Morris Michigan
front and rear bearing. front was the worst.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2133272
08/15/16 03:50 AM
08/15/16 03:50 AM
I install my own cam bearings, I do them one at a time now and check the cam fit with the cam going into that motor on each bearing,I corrrect(scrape them with a bearing knife) as needed before installing the next one up
