fitting a cam into a fresh 400 block #2129558
08/10/16 03:34 PM
08/10/16 03:34 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I fit the cam into the block, but it binds in one spot while rotating. should I scotch brite the bearing til it rotates freely or is it no big deal and leave alone?
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129560
08/10/16 03:38 PM
08/10/16 03:38 PM
Mt Morris Michigan
Mt Morris Michigan
I can still rotate cam, just snug in one spot.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129589
08/10/16 04:21 PM
08/10/16 04:21 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Sometimes I take a bearing knife and cut the shiny spot off until it turns free and sometimes I just run it. I've never had a bad experience, and some of them I thought were way too tight.
2011 Drag Pak Challenger
Re: fitting a cam into a fresh 400 block [Re: rickseeman] #2129599
08/10/16 04:30 PM
08/10/16 04:30 PM
Mt Morris Michigan
Mt Morris Michigan
OK, sounds like no big deal. Thanks
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129639
08/10/16 05:27 PM
08/10/16 05:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If you know where the spot is... clearance it..
it should spin freely with just using your hand
and spin a few turns
wave
Re: fitting a cam into a fresh 400 block [Re: MR_P_BODY] #2129702
08/10/16 06:41 PM
08/10/16 06:41 PM
Mt Morris Michigan
Mt Morris Michigan
Yes, when I pulled the cam out I did find marks on the upper part of front and rear cam bearing only. I can scotch Brite them. It's all I have for dressing bearings
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129706
08/10/16 06:43 PM
08/10/16 06:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Make yourself a reamer by making diagonal hacksaw cuts in each bearing journal of an old cam.
Re: fitting a cam into a fresh 400 block [Re: John_Kunkel] #2129725
08/10/16 07:15 PM
08/10/16 07:15 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have one of these sizer cams but its for a SB.. nothing
for a B or RB
wave
Re: fitting a cam into a fresh 400 block [Re: John_Kunkel] #2129746
08/10/16 07:47 PM
08/10/16 07:47 PM
Mt Morris Michigan
Mt Morris Michigan
OK. That's interesting. Why can't I just use a scotch Brite pad and rub out the wear spots? Shouldn't take much.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129771
08/10/16 08:31 PM
08/10/16 08:31 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
It will take a while with the Scotch Brite.DAMHIK...
Nautilus Racing-
Re: fitting a cam into a fresh 400 block [Re: Chris2581] #2129810
08/10/16 09:25 PM
08/10/16 09:25 PM
Mt Morris Michigan
Mt Morris Michigan
Not rubbing bad. Never had the issue before. The shop was suppose to fit the cam. Guess they didn't.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2129868
08/10/16 10:23 PM
08/10/16 10:23 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
because scotchbrite is an abrasive and will leave minute particles of that abrasive in the bearing surface also you will need to wash the block out again if you haven't already done so,,a bearing knife is the proper way.
Re: fitting a cam into a fresh 400 block [Re: dartman366] #2129924
08/10/16 11:12 PM
08/10/16 11:12 PM
Mt Morris Michigan
Mt Morris Michigan
Ok
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2130002
08/11/16 12:16 AM
08/11/16 12:16 AM
It sounds like you have bent cam to me, especially if it is a Mopar brand cam scope Set that rascal up in a set of V blocks with dail indicator and see if it is bent scope
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2130022
08/11/16 12:30 AM
08/11/16 12:30 AM
Mt Morris Michigan
Mt Morris Michigan
That's what I first thought, but I remembered moparts usually have cam alignment issues with the
bearings. It is a comp solid flat tappet that has been nitrated.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2130030
08/11/16 12:33 AM
08/11/16 12:33 AM
Check it first and go from there up Let us know if it is warped or bent up
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2130066
08/11/16 02:05 AM
08/11/16 02:05 AM
Mt Morris Michigan
Mt Morris Michigan
ok
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2130447
08/11/16 05:42 PM
08/11/16 05:42 PM
dogdays Offline
dogdays  Offline
Scrape the bearing with a single edged razor blade. You only need to take off a little and the shiny spots will show you where. Or you could blue all the bearings, install the cam, rotate it a couple of times and see that way. It's possible that when you get the first areas scraped, there will be contact somewhere else.
Keep the razor blade about perpendicular to the surface.
Scotchbrite has those particles, but it also isn't very precise and that's what I worry about.
Re: fitting a cam into a fresh 400 block [Re: Cab_Burge] #2131133
08/12/16 02:43 PM
08/12/16 02:43 PM
Mt Morris Michigan
Mt Morris Michigan
ok, I checked the cam for straightness. looks like .0005-.001 out. I scraped the bearings with a sharp pocket knife and blended with scotch brite pad. spins good now without binding, but is a snug fit.
Re: fitting a cam into a fresh 400 block [Re: mopar dave] #2131149
08/12/16 02:56 PM
08/12/16 02:56 PM
I thought it had to be bent some to not rotate freely. I have heard of some people straightening them with a hammer and a dull chisel, NOT ME though tsk You should be good, I have had to scrape more than one new cam bearing due to Mopars poor machining of the cam tunnel not getting one or more of them not the proper I.D. runaway One of the better machine shops I use to use in SO CA would use a small cylinder hone to enlarge them work up
