Re: fitting a cam into a fresh 400 block
[Re: Cab_Burge]
#2131188
08/12/16 03:25 PM
08/12/16 03:25 PM
Posts: 25,801 Rio Linda, CA
John_Kunkel
Rio Linda, CA
According to E-booger the factory align-bored cam bearings after installation.
[Re: mopar dave]
#2131193
08/12/16 03:29 PM
08/12/16 03:29 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
ok, I checked the cam for straightness. looks like .0005-.001 out. I scraped the bearings with a sharp pocket knife and blended with scotch brite pad. spins good now without binding, but is a snug fit. You really have a hard on for the scotch brite pad , its not something that should be used on an assembled motor , nevermind a bearing ... What do you mean by it spins good ? Put a gear on it and spin it , does it stop immediate is you try to spin it fast and let go or does it do a revolution or 2 ? If it stops you still have high spots ... more scotch brite ...
[Re: mopar dave]
#2131195
08/12/16 03:29 PM
08/12/16 03:29 PM
JohnRR
U.S.S.A.
ok, I checked the cam for straightness. looks like .0005-.001 out. I scraped the bearings with a sharp pocket knife and blended with scotch brite pad. spins good now without binding, but is a snug fit. You really have a hard on for the scotch brite pad , its not something that should be used on an assembled motor , nevermind a bearing ... what do you mean by it spins good ? Put a gear on it and spin it , does it stop immeadiate is you try to spin it fast and let go or does it do a revolution or 2 ? If it stops you still have high spots ... more scotch brite ...
[Re: John_Kunkel]
#2131355
08/12/16 07:17 PM
08/12/16 07:17 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
According to my old machinest you can't align hone the cam tunnel on any modern day(1951 to current production as of 2003) Mopar V8 due to the tunnel has five diofferent sizes, just like the cam journals have Maybe Ebooger thought they honed them after installing the bearings on the blocks that the cam would stick in It never ceases amaze me to hear urban myths repeated over the internet, supposidily from a relaiblle source
[Re: mopar dave]
#2131922
08/13/16 01:49 PM
08/13/16 01:49 PM
Cab_Burge
[Re: Cab_Burge]
#2132075
08/13/16 05:03 PM
08/13/16 05:03 PM
John_Kunkel
Rio Linda, CA
According to my old machinest you can't align hone the cam tunnel on any modern day(1951 to current production as of 2003) Mopar V8 due to the tunnel has five diofferent sizes, Sure you can, just use a boring tool with five different cutter diameters. Don't confuse align- boring with align- honing.
[Re: mopar dave]
#2132591
08/14/16 12:28 PM
08/14/16 12:28 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
As said common issue with bb mopar. Don't sweat it. Ive seen cams that would barely turn with a wrench on the bolt, after some run time it turned like it was on roller bearings. If you only had to massage just one spot on one bearing you got a good block...
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: Cab_Burge]
#2132675
08/14/16 02:42 PM
08/14/16 02:42 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I never did understand why they made each bearing size different... my 50mm rollers works just fine with all of them being one size
