seal puller #2128842
08/09/16 06:31 PM
08/09/16 06:31 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
Dumb question but never done it before. Will a regular parts store seal puller work on pulling the front seal from a 904 transmission? Just not a lot of room between the seal edge and the input shaft. Trans is in the car. Thanks for any help.
Re: seal puller [Re: 69fish] #2128896
08/09/16 08:00 PM
08/09/16 08:00 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Re: seal puller [Re: 69fish] #2128911
08/09/16 08:21 PM
08/09/16 08:21 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
Yep, thanks!
Re: seal puller [Re: 69fish] #2128914
08/09/16 08:24 PM
08/09/16 08:24 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When installing the new seal, pack the garter spring with grease to prevent it popping off when pounding it in.
Re: seal puller [Re: John_Kunkel] #2128923
08/09/16 08:32 PM
08/09/16 08:32 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
This type of puller will save you a few headaches, if you were professionally wrenching for a living.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: seal puller [Re: hemi71x] #2129066
08/09/16 11:13 PM
08/09/16 11:13 PM
pass christian, ms
69fish Offline OP
69fish  Offline OP
pass christian, ms
Pretty sure I would starve trying to do it for a living but you can tell that's a professional tool. John, I will use your tip, I never would have thought about it. I just would have put TF on the lip of the seal. Thanks again.
Re: seal puller [Re: John_Kunkel] #2129648
08/10/16 05:39 PM
08/10/16 05:39 PM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Originally Posted By John_Kunkel
. Spend the bucks for a name brand. One hard tug destroyed my HF version on wife's T Bird pinion seal. Had to use a brass drift and hammer to get it out as no stores were open that evening.
Re: seal puller [Re: Sxrxrnr] #2129700
08/10/16 06:40 PM
08/10/16 06:40 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
. Spend the bucks for a name brand. One hard tug deysttoyed my HF version on wife's T Bird pinion seal. Had to use a brass drift and hammer to get it out as no stores were open that evening.
IMO Lisle is a "name brand" plenty good enough for hobby use.
Sure it is may not be snapon. matco, cornwell or mac etc quality but heads above HF which is at the bottom quality wise as you found out with some tools.
I have used many Lisle tools over the years, sears used to sell some Lisle tools too.
Re: seal puller [Re: Challenger 1] #2130089
08/11/16 04:13 AM
08/11/16 04:13 AM
Northern Calyfornua
Sxrxrnr Offline
Sxrxrnr  Offline
Northern Calyfornua
Sorry for any misunderstanding. I too consider Lisle stuff of fine quality.
