Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: ScottSmith_Harms] #212777
02/03/09 10:28 PM
02/03/09 10:28 PM
Green Lane, PA
sawdust Offline
sawdust  Offline
Green Lane, PA
Had a Vanke with stock carbs on one of our auto hemi 66 satellites, and it had zero bottom end. Really needed a high stall converter as low end would not run correctly, total bog mobile. Would love to see numbers on dyno for modern day assessment.
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: sawdust] #212778
02/03/09 11:09 PM
02/03/09 11:09 PM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Mine looks just the same only the welding is a little neater.
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: fastmark] #212779
02/04/09 12:22 AM
02/04/09 12:22 AM
Sacramento,California
JRepucci Offline
JRepucci  Offline
I'm using mine on a 426 cid engine with RO/WO cheater carbs(2 750 cfm carters 4325,4326), Racer Brown .590 solid cam and NOS 2" "hustle stuff" header....should make around 425 hp:)
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede #212780
02/04/09 12:45 AM
02/04/09 12:45 AM
Blairsden, CA
Triggerfish Offline OP
Blairsden, CA
Looks like mine's just a hack job that someone pawned off as the real deal. Here's a pic that shows how both plenums are totally hogged out. I recently bought one from John Arruzza, to go w/ a larger cam (solid flat tappet) & 750 eddys, but am worried that I'll loose a lot of low end & mid range. A Stage 5 intake will make a lot more power & torque, but will loose the stock look. I'm also concerned about the correct height for my Shaker.
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede #212781
02/04/09 07:40 AM
02/04/09 07:40 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
It is much harder to find a hemi intake that has NOT had this modification than ones that DO have it. If the manifold is date coded correct and has the modification there is no way to prove or disprove who or when it was done.
Where is the date code?
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: Triggerfish] #212782
02/04/09 10:44 AM
02/04/09 10:44 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Sounds like you paid more for it because someone CLAIMED it was an original race piece , unless you have an original RO/WO car that you are restoring that would make little sense , but it's your money , I'm not here judging you .
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212783
02/04/09 11:34 AM
02/04/09 11:34 AM
Blairsden, CA
Blairsden, CA
I was looking for performance parts for a hemi I was building that would keep the stock look & was told the Vanke intake would be the ticket. But being a novice & trusting a "friend's" advice, I bought it. Too bad I bought it when Mopar cars & parts (especially Hemi), were at their zenith.
I wanted to compare it to the repop I bought from Arruzza & see which one would perform the best.
Here's a pic of the numbers.
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: Triggerfish] #212784
02/04/09 11:52 AM
02/04/09 11:52 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
fastmark sent me his pics , I'll get them up later .
I also have a vanke modded intake at home , never noticed the internal added dams , I'll have to check it out .
opening the plenum does kill the bottom end torque , done to help on the launch and give more plenum volume for the top end , not a good idea I would think for a street car .
Trigger , you mentioned the stage 5 intake , there is available a shaker baseplate to use that intake , incase you didn't realize that .
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212785
02/04/09 08:50 PM
02/04/09 08:50 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I briefly ran a Vanke about 1980 in a street car with automatic, stock convertor and it ran pretty darn well. It didn't fall on it's face in comparison with a stock intake on the low end. If I only had a 426 and I wasn't happy with the lowend I would just put some convertor into it, I don't think the lowend would be a deal-breaker.
Sheldon
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: RUNCHARGER] #212786
02/04/09 10:44 PM
02/04/09 10:44 PM
JRepucci Offline
JRepucci  Offline
4.10 gear would be good.....4.56's would be great.
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212787
02/04/09 11:28 PM
02/04/09 11:28 PM
Blairsden, CA
Blairsden, CA
I know they make a Shaker baseplate, but the Stage 5 doesn't look stock. The Shaker pretty much hides the carbs & most of the intake, so it may be an option. I could modify my baseplate to fit the larger eddys, so that would save some $$.
I've got a Dana w/ 3.73's & a 4 spd & a decent lift solid lifter cam, so a little higher powerband might be ok. THe Chally's over 4K lbs w/ the hemi, so need all the torque the hemi will give. I noticed the welded in dams on the vanke photo & my Arruzza repop doesn't have that feature. Maybe I should weld it in? I only plan on spinning the motor to 6500, so do you think the Vanke mod is a good idea?
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: Triggerfish] #212788
02/05/09 06:14 PM
02/05/09 06:14 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You have to open up the holes , spread them as the carbs are further apart , AND make the base a drop base because the intake is taller .
When the shaker is on no one can see the intake , plus it's worth 50HP .
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212789
02/05/09 06:16 PM
02/05/09 06:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
here are fastmarks pics , sorry for the delay
#1
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212790
02/05/09 06:16 PM
02/05/09 06:16 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
#2
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212791
02/05/09 06:17 PM
02/05/09 06:17 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
#3
Re: Photo of authentic Vanke 67 WO/RO hemi intake neede [Re: JohnRR] #212792
02/06/09 01:24 AM
02/06/09 01:24 AM
Blairsden, CA
Blairsden, CA
Thanks for the photo. It shows the welded in dam clearly. Is its purpose to equalize the distance air has to flow, to compensate for the unequal length runners? Does it add low end torque? I'm about to go w/the Stage 5 intake & eddy 750's & sell the "vanke" repop that John made. Shoot, if I sell it w/ the original 69 hemi carbs, that'd pay for the cam swap & Stage 5 setup, too.
