Re: 2007 Ram. Speedo calibration after axle gear change???
[Re: stumpy]
#2125396
08/05/16 01:05 AM
08/05/16 01:05 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
You don't need to recalibrate the speedometer with a gear change. It is only required when tire size is altered.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Kern Dog]
#2125417
08/05/16 01:28 AM
08/05/16 01:28 AM
71yelladustr
Missouri U.S.A.
The rear wheel speed sensor reads off of a tone wheel mounted on the differential carrier that turns the same revolutions as the tire and wheel. It does not care how many times the pinion turns in every revolution of the wheel.
[Re: Kern Dog]
#2126132
08/05/16 10:11 PM
08/05/16 10:11 PM
Posts: 16,164 Mesa, Arizona
dart4forte
Mesa, Arizona
I have the Edge and I change my tire ratio with it
Abe Lincoln
