2007 Ram. Speedo calibration after axle gear change??? #2125307
08/04/16 11:23 PM
08/04/16 11:23 PM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
I'm guessing that with everything electronic, a change in axle gears means a trip to the dealer to get the speedometer reading right again?
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2125365
08/05/16 12:24 AM
08/05/16 12:24 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Or you could get one the tuners that does it and get to play with a plug in horsepower upgrade. You might be able to find an unlocked used one on Ebay. Other than that it's a trip to the dealer. grin
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: stumpy] #2125396
08/05/16 01:05 AM
08/05/16 01:05 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
You don't need to recalibrate the speedometer with a gear change. It is only required when tire size is altered.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: 71yelladustr] #2125405
08/05/16 01:16 AM
08/05/16 01:16 AM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
How would that be true? Tire diameter affects the reading just like the gear ratio difference will.
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2125417
08/05/16 01:28 AM
08/05/16 01:28 AM
Missouri U.S.A.
Missouri U.S.A.
The rear wheel speed sensor reads off of a tone wheel mounted on the differential carrier that turns the same revolutions as the tire and wheel. It does not care how many times the pinion turns in every revolution of the wheel.
10.02@134
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2125465
08/05/16 03:03 AM
08/05/16 03:03 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
I believes that yellow is correct.
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2125922
08/05/16 06:26 PM
08/05/16 06:26 PM
Austin, TX
lunacy Offline
lunacy  Offline
Austin, TX
yup, speedometers on those trucks read off the rearend. Changing gears doesn't matter, I changed my 05 from 3.52 to 3.92 and speedometer was fine. Changing tire diameter is all that matters on those trucks. In the older truck where it reads off the transmission you have re-calibrate of you change anything down stream rear end or tires.
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2125984
08/05/16 07:34 PM
08/05/16 07:34 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Darn I learned something new. up
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2126079
08/05/16 09:03 PM
08/05/16 09:03 PM
Granite Bay CA
Kern Dog Offline OP
Kern Dog  Offline OP
Granite Bay CA
Yeah, thanks guys. I appreciate the help.
Re: 2007 Ram. Speedo calibration after axle gear change??? [Re: Kern Dog] #2126132
08/05/16 10:11 PM
08/05/16 10:11 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have the Edge and I change my tire ratio with it
Abe Lincoln
