Installing AN fitting's on Braided Line ! arrrrgghhhhhh
#2125119
08/04/16 07:06 PM
08/04/16 07:06 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
I have done it before,,,usually takes several practice runs to get it right,,,( lol ) I hate doing this stuff,,,, Any trick's that you guys use when installing.. ?
I usually tape the line,,,use a cut off wheel,,,and then wrestle getting the fitting over the fresh cut line,,,this is the part that i struggle with,,,always seem's to start to fray as i try and get the fitting on...
ps,,,any trick's for doing it with the line on the car ? ( ie,,,with out a vice ? ) I have to change a fitting,,,but taking the whole line off ( from the trans, headers, shifter linkage, etc ) is a PITA...
Re: Installing AN fitting's on Braided Line ! arrrrgghhhhhh
[Re: rickraw]
#2125144
08/04/16 07:40 PM
08/04/16 07:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I use electric tape. Wrap it as tight as I can, cut with thin cut-off wheel. I trim the frayed braids with the flat side of the cutoff wheel. Works great for me. Same way I did it with the stainless stuff... I use the black stuff now.. just did one today... cuts with tin snips and the nut portion slides right on... no more stainless for me... and I still have a good selection of it in the shop.... from #4 up to either #16 or its #20
[Re: 69CHARGERMD]
#2125148
08/04/16 07:48 PM
08/04/16 07:48 PM
69CHARGERMD
KENTUCKY
Mike,,,,does the "black" stuff use the same type of AN fittings ? might just do that,,,, this braided stuff is a pain Where did you get your ? Summit ? thx, Doug
[Re: 69CHARGERMD]
#2125154
08/04/16 07:54 PM
08/04/16 07:54 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I used the Black Russell Line..
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: 69CHARGERMD]
#2125166
08/04/16 08:10 PM
08/04/16 08:10 PM
Posts: 7,506 Az
Crizila
Az
Buy a braided stainless line hose cutter and save yourself a lot of grief.
Fastest 300
[Re: 69CHARGERMD]
#2125201
08/04/16 08:59 PM
08/04/16 08:59 PM
Posts: 11,602 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
3/4" reinforced packing tape (the stuff with the fiberglass strands), small cut off wheel, trim any frays. Pull the tape off and get the nut on it right away because it will begin to fray out. Easy. The brand makes a difference. Aeroquip nuts have a nice chamfer that makes it easy to get started.
[Re: 69CHARGERMD]
#2125221
08/04/16 09:42 PM
08/04/16 09:42 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
Ditch the stainless! I buy all my AN line and fittings from: getfast1 on eBay. He also has a website. I believe the site is: www.getfast1.comI've been using the black braided hose. It has the stainless wire embedded in the hose rubber with a braided nylon jacket. Takes standard AN fittings.
unions....the folks who brought you the weekend!
[Re: 69CHARGERMD]
#2125265
08/04/16 10:36 PM
08/04/16 10:36 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I just made my fuel system with Fragola cloth braided lines. It is so much easier than stainless its unreal. My trans lines and rad hoses are stainless but I will likely change them eventually.
68 Barracuda Formula S 340
[Re: 69CHARGERMD]
#2125343
08/04/16 11:59 PM
08/04/16 11:59 PM
Posts: 1,102 Massillon, Ohio
cudatom
Massillon, Ohio
I used to wrap and use a cut off wheel. What a PITA.
Then I picked up a Summit hose cutter. Very simple, takes me about 2 minutes per end.
Many have stated they don't like the Summit fittings. That's all I have on my car. I used their hose and fittings. Theirs are the only fittings that I have been able to take apart and reuse if I cut the hose too long and need to trim more off.
Ok
[Re: 69CHARGERMD]
#2125414
08/05/16 01:24 AM
08/05/16 01:24 AM
Posts: 5,163 CT
GTX MATT
CT
The Russel black bylon braided works nice FWIW, very easy. I cut it with a regular hack saw with a fine tooth blade.
[Re: 69CHARGERMD]
#2125438
08/05/16 02:03 AM
08/05/16 02:03 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Fragola push n lok is complete garbage stay away. I use Frozenboost stainless ptfe and fittings. Gorilla tape and cut off wheel. Cake.
Mopar to the bone!!!
