Oil filters, remote adapters and oil coolers...step inside! #2124829
08/04/16 02:02 PM
08/04/16 02:02 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Hey everyone,
I'm looking into the cheapest/easiest but most effective way to run an engine oil cooler for my boosted 340 project. Since I'll be running half filled block on the street, even with the cool running E85, I definitely want something to keep the oil temps down on extended street cruises.
I really didn't want to run a remote oil filter, just more money and work to install. It seems like it may be the only way to go. I am guessing there is no sandwhich adapter out there that could go between a short style filter and the block with AN fittings for a cooler built into it that would clear most headers?
What do you guys recommend? In all likelihood I will probably going with TTI headers, but if I get cheap I may just weld W2 Econo style flanges onto my Hooker SuperComps to work with my single pattern W2 Econo heads.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2124847
08/04/16 02:15 PM
08/04/16 02:15 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2124968
08/04/16 04:29 PM
08/04/16 04:29 PM
I would tap the block for NPT fittings and use a dual remote oil filter adapter to expose the oil filters to air flow using AN hoses to the remote adapter up twocents I wouldn't plumb a oil cooler unless you find out that you really need it. I would, and do, use 240 F as the cut off on the oil temps. for using a engine oil cooler on petroleum based oils twocents
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2125673
08/05/16 01:15 PM
08/05/16 01:15 PM
1mean340 Offline OP
1mean340  Offline OP
Justinp61, thanks for the link! Have you tried that with a short oil filter and headers? I can't remember what kind of clearance I had on my Ebody and hooker super comps (I ran a 90 degree adapter that I hated) and my motor is at the machine shop so I can't check to see if that would fit along with a short filter.
Cab, why don't you recommend going with an oil cooler? I was thinking that it may not be the best idea for cold starts or winter cruising, but with the thermostatic oil filter sandwich adapter I figured it wouldn't be too big of a deal.
I was thinking for a half fill block, iron heads and boost that I'd never have a problem with engine oil being too cold....but I will be running an 8qt pan and E85 is known for it's cool combustion temps so I guess there is a possibility that I won't have oil temp issues without a cooler.
I just hate having to find out the hard way, cruising with friends in the summer or what not and having to do the park and limp home.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2125709
08/05/16 01:54 PM
08/05/16 01:54 PM
I had a Cyberdyne digital temperture gauge on my old pump gas Duster with a three way switch on it so I could read the water temp, oil temp or tranny tempatures on one gauge. That motor made over 700 HP on pump gas, the highest oil temp I saw on it here in the summer was 210 F when the engine coolant temps where 230 F shruggy It had no extra oiling cooling features in it, stock 1970/71 Hemi 6 quart oil pan with the standard size Ford Mopar oil filter work
I've seen many hot rodders over build many features like you want to do and the motors wouldn't get hot enough (above 160 F)to make the coolants and oils work properly shruggy Put a oil temperature gauge on it first and go from there thumbs twocents
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2125737
08/05/16 02:42 PM
08/05/16 02:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I haven't tried the part in the link. My block is drilled and tapped for a remote filter. I don't run a cooler though.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126008
08/05/16 07:48 PM
08/05/16 07:48 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
I mean340, i'm about to be building a 408 with 2/3 filled block for the street so am also a little concerned with temps, unfounded and untested but its in the back of my mind. I have a remote filter set up already. That said, Id like to know where is the best place to locate the oil temp sender, i'm guessing in the pan????, I will run it and see what I end up with before adding coolers etc. I will be running 98 pump gas EFI, 11.5 CR. iron W2 heads.
so, some say make sure your radiator is up to the task particularly your fan set up, we know the top of the block is hottest and we have water there. we also know that as we have less water in the block the duty cycle if you will of the water is quicker as there is not as much so it gets run through the radiator more often so possible cools better,,,,maybe,,,.
Anyway, it'll be interesting to see the outcome
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126011
08/05/16 07:51 PM
08/05/16 07:51 PM
Brisbane Australia
crash520 Offline
crash520  Offline
Brisbane Australia
Oh, also, I have an LA block, oil will go from the block to the filter then on the return line back it splits, one line goes back into the block at the old filter location, the other line enters the rear china wall and is taken to the front of the block to feed #1 main (similar to the race blocks), this may help me some with oil temps,,,,maybe! just guessing
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126015
08/05/16 07:54 PM
08/05/16 07:54 PM
If you drill and tap the block for the NPT fittings to use a remote oil filter adapter( much easier and less messy changing oil filters when the bottoms are pointed down instead of sideways work) You can always add the cooler later with that thermostatic adapter later shruggywork
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126058
08/05/16 08:31 PM
08/05/16 08:31 PM
Australia
L4staero Offline
L4staero  Offline
Australia
I use these oil adaptor plates. CNC'd and sold by a Moparts member.
Oil plate
All our Australian cars require a remote oil filter as the position of the steering box doesn't allow a filter to be mounted on the block.
These are the best plate Ive used to date.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126227
08/06/16 12:08 AM
08/06/16 12:08 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah I have had to run a engine oil cooler in my Barracuda 528 half filled engine, I had seen 260F in summer so that was my need. I purchased a cheap sandwich plate but drilled it out to -10 fittings and ported it out for max flow before I put it on, car now runs 230F max .
1963 Plymouth Max Wedge
1971 Barracuda
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126526
08/06/16 01:26 PM
08/06/16 01:26 PM
AndyF Offline
AndyF  Offline
Pretty simple on a small block
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126626
08/06/16 05:14 PM
08/06/16 05:14 PM
pennsylvania
poboyengineering Offline
pennsylvania
Andy, what size lines are those?
I have one that came with -10, but I've seen others that use -12.
I would assume this is a case where size matters, and bigger is better?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: poboyengineering] #2126646
08/06/16 06:04 PM
08/06/16 06:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I just ordered a remote set up(for the block) I will
be using #10an.... I had all the other stuff already
wave
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: 1mean340] #2126703
08/06/16 07:44 PM
08/06/16 07:44 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I used 10 also.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: poboyengineering] #2126786
08/06/16 10:54 PM
08/06/16 10:54 PM
AndyF Offline
AndyF  Offline
I always use #12 for the lines if it will fit. I have a dry sump set up with a #20 line from the tank to the pump.
Re: Oil filters, remote adapters and oil coolers...step inside! [Re: AndyF] #2126809
08/06/16 11:19 PM
08/06/16 11:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Most plates(engine side) and the filter side are 1/2
NPT... the supply side on the block is 1/2" max..
closer to a large 3/8".. I drill the pipe fitting a bit
larger for less restriction... never had any issues doing
it that way.. I'm only putting on a remote on this engine
is its a PITA to get the filter past the header and its a
short filter
wave
