on the Packard 56 types, on the new ones you will see a tab on the back flat side & you want to raise it up up a bit from "flush" so when you pull the crimped/soldered wire/new terminal backwards into the connector the tab will "snap" (you'll hear it) which locks it into place. also fit each female terminal with one of the males & crimp the curved edges of the females just right so each "pair" has a snug fit cuz you dont want to have to seperate everything right when you are connecting the two halves back together. I would suggest some Kopprcoat (brand name) or dielectric grease on the males. when removing the old females, stick an eyeglass mini screwdriver down in the rectangle in the connector on the back side & depress that aforementioned tab & when it is depressed the right amt the wire/terminal will easily pull out the back side & if it wont then go back in with the screwdriver till it will. EDIT on depressing the tab on the old ones do not use the connector rectangle "walls" as leverage by angling the screwdriver, instead move the screwdriver held straight, "in" to depress the tab further toward "flush" as needed
