Hose for external oiling system #212452
02/02/09 11:00 PM
02/02/09 11:00 PM
San Diego
formula S Offline OP
San Diego
I was told that regular steel braid hose would collapse if used as a suction hose, what do you guys think?
Re: Hose for external oiling system [Re: formula S] #212453
02/02/09 11:01 PM
02/02/09 11:01 PM
an8sec70cuda Offline
That's BS. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hose for external oiling system [Re: an8sec70cuda] #212454
02/02/09 11:04 PM
02/02/09 11:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I'll second the bs part..
Re: Hose for external oiling system [Re: formula S] #212455
02/02/09 11:16 PM
02/02/09 11:16 PM
What kind of system, how long and which type of stainless covered hose are you talking about?
Re: Hose for external oiling system [Re: Cab_Burge] #212456
02/02/09 11:49 PM
02/02/09 11:49 PM
ohio
flynbyu Offline
flynbyu  Offline
ohio
X3 on the bs...thats what came with my milodon pan
Re: Hose for external oiling system [Re: flynbyu] #212457
02/03/09 12:05 AM
02/03/09 12:05 AM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
x4
1.39 9.85 - 137 mph
Re: Hose for external oiling system [Re: Ari440] #212458
02/03/09 12:21 AM
02/03/09 12:21 AM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
It shouldn't, mine has never had a problem but if your really worried use TFE stainless braid
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Hose for external oiling system [Re: Ari440] #212459
02/03/09 12:23 AM
02/03/09 12:23 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
The only way you might collapse it is drive over it with a truck. If you have that strong of a pump you might think about reinforcing your valve covers.
Re: Hose for external oiling system [Re: rowin4] #212460
02/03/09 01:47 AM
02/03/09 01:47 AM
San Diego
San Diego
A friend of mine has a B1 KB 572 with a KB oil pump, and KB told him to use this special suction hose, that I can't think of the name, but I did see the hose, and it has different hose fittings it looks like they are sweged and not reuseable. I really dont think that the steel braid part of the hose would collapse, but maybe the the non steel reenforced rubber hose inside would, I dont know just a thought.
Re: Hose for external oiling system [Re: formula S] #212461
02/03/09 01:59 AM
02/03/09 01:59 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If you kink or fold the SS hose you can cause seperation of the inside lining and it can collaspe blocking the passage under suction.Make all curves smooth and use proper fittings:90,45,22 degrees and straight.
Re: Hose for external oiling system [Re: formula S] #212462
02/03/09 02:27 AM
02/03/09 02:27 AM
AndyF Offline
AndyF  Offline
Use the Aeroquip blue hose if you're worried about suction. Besides, the blue hose is a lot less expensive and is easier to assemble. I don't use much of the braided hose anymore since it is kind of a hassle to deal with.
Re: Hose for external oiling system [Re: AndyF] #212463
02/03/09 02:50 AM
02/03/09 02:50 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've used braided hose for the vac line on my brake booster for years, never seen it collapse, & my brakes work great.
Re: Hose for external oiling system [Re: rebel] #212464
02/03/09 03:01 AM
02/03/09 03:01 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I had a milodon hose on mine and after a few months it was soft, when it was cold, it must have been real soft after the oil was up to temp.
I still have that hose.
its not BS
Re: Hose for external oiling system [Re: 70blackfish] #212465
02/03/09 03:18 AM
02/03/09 03:18 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
There are a few diffrent grades of SS hose.We have seen new stuff that collaspes,usually if you have good pressure at idle and loose it as you increase rpm and regain it when you go back to idle rpm is a good indication that the liner is collasping.If you pull the hose and look through it you will the lumps in the liner,sort of looks like a hemmoroid in you rectal colon.
Re: Hose for external oiling system [Re: B G Racing] #212466
02/03/09 03:22 AM
02/03/09 03:22 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you got any pics of that so we know what we are looking at?
Re: Hose for external oiling system [Re: rebel] #212467
02/03/09 03:50 AM
02/03/09 03:50 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
you got any pics of that so we know No,try bending over in front of a full length mirror and spread your butt. But seriously just take a scrap piece of SS hose fold it over a couple of times,you will feel and hear the lining seperate,then look through the hose and you will see what looks like lump in the lining.
Re: Hose for external oiling system [Re: B G Racing] #212468
02/03/09 10:20 AM
02/03/09 10:20 AM
San Diego
San Diego
Now that's funny right their, I don't care who you are
Re: Hose for external oiling system [Re: B G Racing] #212469
02/03/09 10:40 AM
02/03/09 10:40 AM
San Diego
San Diego
So with all the different hoses, which one do we use? Please be specific. Brand,type, part number ect.... And I'll go get it. Thanks guys for all the replies.
Re: Hose for external oiling system [Re: formula S] #212470
02/03/09 11:00 AM
02/03/09 11:00 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We use Aeroquip AQP and Teflon racing hose.
Re: Hose for external oiling system [Re: formula S] #212471
02/03/09 12:26 PM
02/03/09 12:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The hose and fittings you were looking at were what
I believe just hydrolic lines and fittings, we swedge
those fitting (pretty stiff with high burst pressures)
