Progress on the Cuda! #212441
02/02/09 10:45 PM
02/02/09 10:45 PM
Alexandria, VA
SealockRacing Offline OP
Alexandria, VA
finished up running some new pieces of brake line, mounted the calipers, and used my new aeroquip fittings to connect everything.
also mocked up a new steering wheel...i think ill need a quick release though.
heres a pic of the drivers side, all mocked up
Re: Progress on the Cuda! [Re: SealockRacing] #212442
02/03/09 12:23 AM
02/03/09 12:23 AM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
how old are those calipers
Re: Progress on the Cuda! [Re: Defbob] #212443
02/03/09 12:43 AM
02/03/09 12:43 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Heck with that, how old are the rotors ? Any progress is good. Keep going and don't rest.. Never , never rest.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Post deleted by Defbob [Re: Defbob] #212444
02/03/09 12:44 AM
02/03/09 12:44 AM
Re: Progress on the Cuda! #212445
02/03/09 01:44 AM
02/03/09 01:44 AM
Alexandria, VA
Alexandria, VA
calipers, and rotors came off of my grandfathers old car
aluminum front end, 330...pretty sure it held records
my dad said that after it was wrecked, he kept the brakes, and my grandfather, and my father, put the hubs on a lathe and made them fit A body spindles...pretty cool.
so those brakes if i had to take a wild guess, i would say 25+ years old... they got some cool history to them!
all i need is 8 1.75" pistons, 2 sets of 1.75" seals, and pads.
all of which are still available!
thanks for the responses
John
Re: Progress on the Cuda! [Re: SealockRacing] #212446
02/03/09 11:03 AM
02/03/09 11:03 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Cool car , keep at it.
Re: Progress on the Cuda! [Re: justinp61] #212447
02/03/09 12:14 PM
02/03/09 12:14 PM
On the run…
BloFish Offline
BloFish  Offline
On the run…
Love it
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Progress on the Cuda! [Re: SealockRacing] #212448
02/03/09 12:23 PM
02/03/09 12:23 PM
STERLING VA
FOOLISH_PLEASURE Offline
STERLING VA
of all the cars your grandfather had I love that car
Re: Progress on the Cuda! [Re: FOOLISH_PLEASURE] #212449
02/03/09 08:44 PM
02/03/09 08:44 PM
Alexandria, VA
Alexandria, VA
Foolish_Pleasure you have been pmed
thanks for the encouragement and kind words guys.
i need to get some new bolts for the steering wheel...grade 8 would be fine right?
also, does anyone make a 3 bolt pattern quick release? if so, i am very interested!
thanks
John Sealock
Re: Progress on the Cuda! [Re: SealockRacing] #212450
02/03/09 08:48 PM
02/03/09 08:48 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Cool man, those rotors look like Strange engineering hats. Keep it up man, best of luck with her.
Re: Progress on the Cuda! [Re: dthemi] #212451
02/03/09 09:21 PM
02/03/09 09:21 PM
Alexandria, VA
Alexandria, VA
probably are, it has strange hubs, and caliper brackets, and then the wilwood calipers.
question for you guys who have had to do the same thing i am, how do you space the caliper from the rotor, i noticed that they need to be moved just a hair towards the middle of the car on both sides for them to be equally spaced on the rotor? im guessing just thin washers/ shims?
