LM-1 or LM-2? #2123183
08/02/16 05:05 AM
08/02/16 05:05 AM
Park Forest, IL
slantzilla Offline OP
Park Forest, IL
Wanting to put a wide band on the Duster when I drop the motor in. Will an LM-2 give me more useful information than an LM-1, or will it just confuse me?
Thanks! wave
Re: LM-1 or LM-2? [Re: slantzilla] #2123198
08/02/16 07:52 AM
08/02/16 07:52 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I've never used a LM1 but have a 2, all mine currently does is read rpm and afr. That's all it'll do as it comes in the box. You can buy it with two o2 sensors. A tps and map sensor would be handy IMO.
Re: LM-1 or LM-2? [Re: slantzilla] #2123214
08/02/16 09:14 AM
08/02/16 09:14 AM
Virginia
V
varunner Offline
varunner  Offline
V
Virginia
I have a LM-2 and will never buy one again. It's never displayed rpm correctly and I have tried everything the tech support suggested. Should have sent it back asap. I'd look at daytona sensors.
Re: LM-1 or LM-2? [Re: slantzilla] #2123253
08/02/16 10:36 AM
08/02/16 10:36 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had an LM2 and the RPM portion looked like a pain to hook up and I never did. It worked well most of the time as just an 02 monitor. When I started down the EFI road I got rid of it and bought an LC2 which is just a just a monitor. It came with a gauge and the ability to wire it into my EFI. It has worked fine so far, I will probably add another one soon.
68 Barracuda Formula S 340
Re: LM-1 or LM-2? [Re: slantzilla] #2123308
08/02/16 11:46 AM
08/02/16 11:46 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Daytona Sensors Wego IV.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: LM-1 or LM-2? [Re: Adobedude] #2123405
08/02/16 02:04 PM
08/02/16 02:04 PM
Park Forest, IL
Park Forest, IL
I just looked at this one. Is there any advantage to a 2 channel when tuning a carb motor?
Re: LM-1 or LM-2? [Re: Bad340fish] #2123442
08/02/16 03:05 PM
08/02/16 03:05 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
IIRC the rpm functionis no more difficult to hook up than a tach. I like mine, when tuning I record, make changes and record again after each change this way I have a graph of each set up and can see the changes. Also I put a note on each recording with the carb set up at the time so l know exactly what I had done. After your carb is tuned you can install a gauge if you want.
http://www.innovatemotorsports.com/xcart/product.php?productid=16340&cat=250&page=2
Re: LM-1 or LM-2? [Re: slantzilla] #2123443
08/02/16 03:05 PM
08/02/16 03:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You can read both banks and tune from there........
Re: LM-1 or LM-2? [Re: slantzilla] #2123456
08/02/16 03:34 PM
08/02/16 03:34 PM
Park Forest, IL
Park Forest, IL
With either an LM-2 or a WEGO will I need a laptop too?
Re: LM-1 or LM-2? [Re: slantzilla] #2123497
08/02/16 04:27 PM
08/02/16 04:27 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I use a laptop at the track when tuning to view the chart. LogWorks3 comes with the unit.
Re: LM-1 or LM-2? [Re: slantzilla] #2123652
08/02/16 08:55 PM
08/02/16 08:55 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
I use my GoPro as a data logger, records everything with volume.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: LM-1 or LM-2? [Re: slantzilla] #2123655
08/02/16 09:00 PM
08/02/16 09:00 PM
Park Forest, IL
Park Forest, IL
Sounds like I can make this pretty complicated. nervous
Re: LM-1 or LM-2? [Re: slantzilla] #2123757
08/02/16 11:59 PM
08/02/16 11:59 PM
Dirty Dena, Maryland
dodge turbo Offline
dodge turbo  Offline
Had a lm-1. Went to the zentronix. With the tweaker board. Cleaned up the inside alot. If i want to log the small box is under my glove box. Got rid of the ALT gauge since it isnt used.....fyi its 21.0 because it isnt running 😉
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: LM-1 or LM-2? [Re: slantzilla] #2124147
08/03/16 04:52 PM
08/03/16 04:52 PM
Park Forest, IL
Park Forest, IL
That is a nice install. thumbs
Re: LM-1 or LM-2? [Re: slantzilla] #2125305
08/04/16 11:21 PM
08/04/16 11:21 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
Dennis
We can make anything complicated.
I have lm2 use rpm (easy to install)just splice into your tach wire and plug into MSD box.
I have a single channel unit, I have bungs in both sides so I can check both banks of engine.
I like it! I added a SSI4 so I can do driveshaft rpm, water temp.
Knowledge is power!
Most problems with innovate products are self inflicted.
Follow wiring, grounding instructions.
I have found innovate tech to be very helpful. I have had mine for 10 + years.
Don
Re: LM-1 or LM-2? [Re: slantzilla] #2125376
08/05/16 12:44 AM
08/05/16 12:44 AM
Park Forest, IL
Park Forest, IL
Thanks Don!
Re: LM-1 or LM-2? [Re: slantzilla] #2127646
08/08/16 03:04 AM
08/08/16 03:04 AM
Park Forest, IL
Park Forest, IL
I ordered an LM-2. I am sure more questions will follow.
Thanks everyone! wave
Re: LM-1 or LM-2? [Re: slantzilla] #2127654
08/08/16 04:15 AM
08/08/16 04:15 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I like my 14point7 Spartan. Uses the newer Bosch LSU 4.9 sensor too.
Mopar to the bone!!!
Re: LM-1 or LM-2? [Re: slantzilla] #2128214
08/08/16 10:04 PM
08/08/16 10:04 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
What all comes with it now?
When I got mine it had a plastic case 5 different cables, incl. obd2 plug in. Some of the cables I forgot I had till I went to use them.
Don
Re: LM-1 or LM-2? [Re: slantzilla] #2128288
08/08/16 11:22 PM
08/08/16 11:22 PM
Park Forest, IL
Park Forest, IL
I ordered the base kit. Looks like an O2 sensor and cable, and a power plug. I also got the card for recording and an extra bung for the other header. I'm sure I'll have to get more stuff as I figure out what all it does.
