LM-1 or LM-2?
#2123183
08/02/16 05:05 AM
08/02/16 05:05 AM
Posts: 20,177 Park Forest, IL
slantzilla
Park Forest, IL
Wanting to put a wide band on the Duster when I drop the motor in. Will an LM-2 give me more useful information than an LM-1, or will it just confuse me? Thanks!
Re: LM-1 or LM-2?
[Re: slantzilla]
#2123253
08/02/16 10:36 AM
08/02/16 10:36 AM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
I had an LM2 and the RPM portion looked like a pain to hook up and I never did. It worked well most of the time as just an 02 monitor. When I started down the EFI road I got rid of it and bought an LC2 which is just a just a monitor. It came with a gauge and the ability to wire it into my EFI. It has worked fine so far, I will probably add another one soon.
68 Barracuda Formula S 340
Re: LM-1 or LM-2?
[Re: Adobedude]
#2123405
08/02/16 02:04 PM
08/02/16 02:04 PM
slantzilla
Park Forest, IL
I just looked at this one. Is there any advantage to a 2 channel when tuning a carb motor?
Re: LM-1 or LM-2?
[Re: Bad340fish]
#2123442
08/02/16 03:05 PM
08/02/16 03:05 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
I had an LM2 and the RPM portion looked like a pain to hook up and I never did. It worked well most of the time as just an 02 monitor. When I started down the EFI road I got rid of it and bought an LC2 which is just a just a monitor. It came with a gauge and the ability to wire it into my EFI. It has worked fine so far, I will probably add another one soon. IIRC the rpm functionis no more difficult to hook up than a tach. I like mine, when tuning I record, make changes and record again after each change this way I have a graph of each set up and can see the changes. Also I put a note on each recording with the carb set up at the time so l know exactly what I had done. After your carb is tuned you can install a gauge if you want. http://www.innovatemotorsports.com/xcart/product.php?productid=16340&cat=250&page=2
Re: LM-1 or LM-2?
[Re: slantzilla]
#2123443
08/02/16 03:05 PM
08/02/16 03:05 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
You can read both banks and tune from there........
Re: LM-1 or LM-2?
[Re: slantzilla]
#2123456
08/02/16 03:34 PM
08/02/16 03:34 PM
slantzilla
Park Forest, IL
With either an LM-2 or a WEGO will I need a laptop too?
Re: LM-1 or LM-2?
[Re: slantzilla]
#2123652
08/02/16 08:55 PM
08/02/16 08:55 PM
Posts: 1,260 New Mexico
Adobedude
New Mexico
I use my GoPro as a data logger, records everything with volume.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
Re: LM-1 or LM-2?
[Re: slantzilla]
#2123757
08/02/16 11:59 PM
08/02/16 11:59 PM
Posts: 468 Dirty Dena, Maryland
dodge turbo
Had a lm-1. Went to the zentronix. With the tweaker board. Cleaned up the inside alot. If i want to log the small box is under my glove box. Got rid of the ALT gauge since it isnt used.....fyi its 21.0 because it isnt running 😉
78 Adventurer 150small block turbo'd 360w/Borg S475....smoke'em
Re: LM-1 or LM-2?
[Re: slantzilla]
#2125305
08/04/16 11:21 PM
08/04/16 11:21 PM
Posts: 2,131 New Lenox IL
cudadon
New Lenox IL
Sounds like I can make this pretty complicated. Dennis We can make anything complicated. I have lm2 use rpm (easy to install)just splice into your tach wire and plug into MSD box. I have a single channel unit, I have bungs in both sides so I can check both banks of engine. I like it! I added a SSI4 so I can do driveshaft rpm, water temp. Knowledge is power! Most problems with innovate products are self inflicted. Follow wiring, grounding instructions. I have found innovate tech to be very helpful. I have had mine for 10 + years. Don
Re: LM-1 or LM-2?
[Re: slantzilla]
#2127646
08/08/16 03:04 AM
08/08/16 03:04 AM
slantzilla
Park Forest, IL
I ordered an LM-2. I am sure more questions will follow. Thanks everyone!
Re: LM-1 or LM-2?
[Re: slantzilla]
#2127654
08/08/16 04:15 AM
08/08/16 04:15 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I like my 14point7 Spartan. Uses the newer Bosch LSU 4.9 sensor too.
Mopar to the bone!!!
Re: LM-1 or LM-2?
[Re: slantzilla]
#2128214
08/08/16 10:04 PM
08/08/16 10:04 PM
cudadon
New Lenox IL
I ordered an LM-2. I am sure more questions will follow. Thanks everyone! What all comes with it now? When I got mine it had a plastic case 5 different cables, incl. obd2 plug in. Some of the cables I forgot I had till I went to use them. Don
Re: LM-1 or LM-2?
[Re: slantzilla]
#2128288
08/08/16 11:22 PM
08/08/16 11:22 PM
slantzilla
Park Forest, IL
I ordered the base kit. Looks like an O2 sensor and cable, and a power plug. I also got the card for recording and an extra bung for the other header. I'm sure I'll have to get more stuff as I figure out what all it does.
