Chassis/Suspension Guys - Rear Spring Rates #212308
02/02/09 08:37 PM
02/02/09 08:37 PM
Riverside, California
Lil Demon Offline OP
I need a little advice here. The Demon weighs 3100 with a 53/47 front to rear bias. I currently have 110# springs on the rear. They sag a little. I want to increase the rear ride height a bit, but cannot go any higher on the perches/mounts. So, I think I could achieve what I want by taking a little of the sag away.
Previously, I called Bickel and he told me I needed 185# springs - there is no way I need 185s, so I bought 140s. I have a brand new set of Bickel 140s that I could put in, but before I do that - I want to ask - is 140 too much spring for the car?
Back half 4-link that now has coil overs in the front, 4.56 gear, 727, and 875-900hp NA.
If I could raise it a hair and perhaps get better performance as well I would be very happy.
So - I guess the question is: With similar cars, who is running what weight spring? And what is the right spring for me.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212309
02/02/09 08:39 PM
02/02/09 08:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
185
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212310
02/02/09 08:54 PM
02/02/09 08:54 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Remember you only need enough spring to hold the
body up so the shock is at its designed working
length, move the lower shock mount up to raise the body
EDIT
correction you should be using 120# springs now and
if you want to lift it(this is assuming you have adjustable
lower mounts) the 140# might be a bit much
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: MR_P_BODY] #212311
02/02/09 10:14 PM
02/02/09 10:14 PM
The mounts are all the way up already - I can't go anymore. I could use the 140s I already have or order 120-125. But, they need to work as well.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212312
02/02/09 10:21 PM
02/02/09 10:21 PM
San Diego
formula S Offline
formula S  Offline
San Diego
Modify the shock mounts to get your desired ride height
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212313
02/02/09 10:42 PM
02/02/09 10:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The big thing is you need to get the shock back
to its design length(about mid travel but check
with the manufacturer)and I'm thinking your loss
of height was the spring collapsing which would
also decrease the design length, IF your at the
top shock mount location I'm also thinking you
have cranked up on the spring adjuster to way up,
if this is true then the stiffer spring MIGHT allow
you to get back to the design length(with lowering
the spring adjuster) and give you enough to lower
the shock mount
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: MR_P_BODY] #212314
02/02/09 11:39 PM
02/02/09 11:39 PM
The shocks are at the top mount setting. The shock mounts cannot be modified nor can I buy any with a different offset - these are single piece Alston's with the 6* angle. The springs are dialed to the normal position to maintain the desired eye to eye length. The car sags a good 1-1/2 to 2 inches if I pull up on my parachute mount.
So - is the 110 too light?
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212315
02/02/09 11:54 PM
02/02/09 11:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
My car weights about the same and i have 130's and i think there to stiff, i was told to use 150's , you could jump on the back and it didn't move. u Unless your going to use it as a tow vehicle lol don't go 185's.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: rowin4] #212316
02/03/09 12:00 AM
02/03/09 12:00 AM
No - I'm definitely not going 185, I'm trying to figure out if:
1) The 110s are too light or correct.
2) If 110s too light, what is correct as I already have a pair of 140s sitting here
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212317
02/03/09 12:10 AM
02/03/09 12:10 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How far up is the spring adjuster/platform from the
bottom?
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212318
02/03/09 12:11 AM
02/03/09 12:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Think I have said this before but lets try again You have the 140's why not throw them on there and see what you get? Easy enough thing to swap out.
I think you already know this but just for a refresher. I have 110's in my heap at 2800, had 120's in the Valiant at 3470 and the old Duster had 110's at 3050. The Vega has 90's if that matters
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Al_Alguire] #212319
02/03/09 02:22 AM
02/03/09 02:22 AM
I know - but my TNT time is going to be really limited and you keep telling me the rear needs to be a little higher. So, I'm wondering if I can dial the front down 1/2" and raise the rear 1". To do that with what I have - it's the 140s. I'm just thinking out loud.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212320
02/03/09 08:01 AM
02/03/09 08:01 AM
Mansfield, Tx
Jacob Pitt Offline
Jacob Pitt  Offline
Mansfield, Tx
My Challenger weighs about 3300lbs with me in it. I just changed the springs from 150 to 110. It did sit the rear down some but the car seems to work better. The car would unload the tire before and now it doesn't. How old are your springs is it possible they are sagging because they are old?
2013 NHRA D4 Stock Champ
#4 in the World IHRA Stock
2x IHRA Div.4 Stock Champ
14x Track Champ
All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Jacob Pitt] #212321
02/03/09 08:19 AM
02/03/09 08:19 AM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
I'd say 130's, or 125's with xtra preload. I run 120# Eibachs with 1" preload. My Dart wieghs 300# less then your car.
Spring, shock and TIRE must be tuned to work with each other
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212322
02/03/09 08:22 AM
02/03/09 08:22 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
All springs are not created equal...The spring rating may vary especially after time. I noticed you have them on an angle too which affects the rate as well. I agree you should 'try them'. Also, by raising the rear height you will decrease the bias front to rear. I'd just be careful to not top-out the shock now. Using the single adj. shock, I foresee suspension movement in your future.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: HardcoreB] #212323
02/03/09 10:15 AM
02/03/09 10:15 AM
I have Koni DAs on it and am well within the setting limits. The springs are the original Koni's and the angle is by design as it is an Alston CEII 4 link. Everything is planned out - it's the weight rating of the spring I'm thinking about.
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212324
02/03/09 11:09 AM
02/03/09 11:09 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think I have said this a few times before but once more wont hurt.
ALL this stuff is just THEORY, be it suspension engine what ever. The only way to KNOW what will happen is to try it. You have the springs, toss them on and give it a try
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Al_Alguire] #212325
02/03/09 11:38 AM
02/03/09 11:38 AM
Lebanon,IN
mr2performance Offline
Lebanon,IN
140's will work fine. Listen to Al. Mike
MR2PERFORMANCE RACE CARS 765 483 9371
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: Lil Demon] #212326
02/03/09 11:51 AM
02/03/09 11:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I might make a suggestion, clean all of the suspension
points to make sure they arent binding. The 140
will be to stiff but try them since you have them.
This stuff isnt theory its math, the one thing that
I dont know on your car is the angle of the shock
to calculate that in ... the closer you get to 45*,
the closer you get to doubling the spring pressure
Re: Chassis/Suspension Guys - Rear Spring Rates [Re: MR_P_BODY] #212327
02/03/09 11:57 AM
02/03/09 11:57 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well while I will agree that math plays a role in this equation there are no absolutes to it. That is one place you will certainly have an issue with the math theory. I have read Morgans book and sometimes it is just as simple as math. I consider the math a good starting point that will get you in the ballpark. After that you have to try different things to see what is optimal for your car.
Having a little more intimate knowledge of the car in question I think the 140's are worth a shot no matter what.
