Chassis/Suspension Guys - Rear Spring Rates
#212308
02/02/09 08:37 PM
02/02/09 08:37 PM
Posts: 3,746 Riverside, California
Lil Demon
I need a little advice here. The Demon weighs 3100 with a 53/47 front to rear bias. I currently have 110# springs on the rear. They sag a little. I want to increase the rear ride height a bit, but cannot go any higher on the perches/mounts. So, I think I could achieve what I want by taking a little of the sag away.
Previously, I called Bickel and he told me I needed 185# springs - there is no way I need 185s, so I bought 140s. I have a brand new set of Bickel 140s that I could put in, but before I do that - I want to ask - is 140 too much spring for the car?
Back half 4-link that now has coil overs in the front, 4.56 gear, 727, and 875-900hp NA.
If I could raise it a hair and perhaps get better performance as well I would be very happy.
So - I guess the question is: With similar cars, who is running what weight spring? And what is the right spring for me.
Re: Chassis/Suspension Guys - Rear Spring Rates
[Re: Lil Demon]
#212310
02/02/09 08:54 PM
02/02/09 08:54 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Remember you only need enough spring to hold the body up so the shock is at its designed working length, move the lower shock mount up to raise the body EDIT correction you should be using 120# springs now and if you want to lift it(this is assuming you have adjustable lower mounts) the 140# might be a bit much
[Re: Lil Demon]
#212313
02/02/09 10:42 PM
02/02/09 10:42 PM
MR_P_BODY
The mounts are all the way up already - I can't go anymore. I could use the 140s I already have or order 120-125. But, they need to work as well.
The big thing is you need to get the shock back to its design length(about mid travel but check with the manufacturer)and I'm thinking your loss of height was the spring collapsing which would also decrease the design length, IF your at the top shock mount location I'm also thinking you have cranked up on the spring adjuster to way up, if this is true then the stiffer spring MIGHT allow you to get back to the design length(with lowering the spring adjuster) and give you enough to lower the shock mount
[Re: Lil Demon]
#212317
02/03/09 12:10 AM
02/03/09 12:10 AM
MR_P_BODY
No - I'm definitely not going 185, I'm trying to figure out if:
1) The 110s are too light or correct. 2) If 110s too light, what is correct as I already have a pair of 140s sitting here
How far up is the spring adjuster/platform from the bottom?
[Re: Lil Demon]
#212318
02/03/09 12:11 AM
02/03/09 12:11 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
Think I have said this before but lets try again You have the 140's why not throw them on there and see what you get? Easy enough thing to swap out. I think you already know this but just for a refresher. I have 110's in my heap at 2800, had 120's in the Valiant at 3470 and the old Duster had 110's at 3050. The Vega has 90's if that matters
[Re: Al_Alguire]
#212319
02/03/09 02:22 AM
02/03/09 02:22 AM
Lil Demon
I know - but my TNT time is going to be really limited and you keep telling me the rear needs to be a little higher. So, I'm wondering if I can dial the front down 1/2" and raise the rear 1". To do that with what I have - it's the 140s. I'm just thinking out loud.
[Re: Lil Demon]
#212320
02/03/09 08:01 AM
02/03/09 08:01 AM
Posts: 2,528 Mansfield, Tx
Jacob Pitt
Mansfield, Tx
My Challenger weighs about 3300lbs with me in it. I just changed the springs from 150 to 110. It did sit the rear down some but the car seems to work better. The car would unload the tire before and now it doesn't. How old are your springs is it possible they are sagging because they are old?
2013 NHRA D4 Stock Champ #4 in the World IHRA Stock 2x IHRA Div.4 Stock Champ 14x Track Champ All using a Ultimate Converter Concepts converter. Call Lenny today 704-892-6837
[Re: Lil Demon]
#212324
02/03/09 11:09 AM
02/03/09 11:09 AM
Al_Alguire
Las Vegas
I think I have said this a few times before but once more wont hurt. ALL this stuff is just THEORY, be it suspension engine what ever. The only way to KNOW what will happen is to try it. You have the springs, toss them on and give it a try
[Re: Al_Alguire]
#212325
02/03/09 11:38 AM
02/03/09 11:38 AM
Posts: 729 Lebanon,IN
mr2performance
Lebanon,IN
140's will work fine. Listen to Al. Mike
MR2PERFORMANCE RACE CARS
765 483 9371
[Re: Lil Demon]
#212326
02/03/09 11:51 AM
02/03/09 11:51 AM
MR_P_BODY
I might make a suggestion, clean all of the suspension points to make sure they arent binding. The 140 will be to stiff but try them since you have them. This stuff isnt theory its math, the one thing that I dont know on your car is the angle of the shock to calculate that in ... the closer you get to 45*, the closer you get to doubling the spring pressure
[Re: MR_P_BODY]
#212327
02/03/09 11:57 AM
02/03/09 11:57 AM
Al_Alguire
Las Vegas
Well while I will agree that math plays a role in this equation there are no absolutes to it. That is one place you will certainly have an issue with the math theory. I have read Morgans book and sometimes it is just as simple as math. I consider the math a good starting point that will get you in the ballpark. After that you have to try different things to see what is optimal for your car.
Having a little more intimate knowledge of the car in question I think the 140's are worth a shot no matter what.
