back wheels turning on jackstands #2122804
08/01/16 06:41 PM
08/01/16 06:41 PM
The Netherlands
Luigi Offline OP
Luigi  Offline OP
The Netherlands
I'm having a problem with my rear drums heating up.Maybe I'll start another thread about that..
Trying to solve that problem I had the back of the car on jackstands. Put in D and only the left wheel turned, right didn't, or just a lttle bit. In Reverse, the right wheel turned and the left didn't.
Is this normal? And yes, the wheels turned free by hand in neutral.
1971 Newport, 383 with 727 trans and standard rearaxle.
Luigi
Re: back wheels turning on jackstands [Re: Luigi] #2122824
08/01/16 07:13 PM
08/01/16 07:13 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
if you have an open rear, only 1 wheel will turn. you need a sure grip to have bolt wheels turning.
easy test. with the back of the car on jackstands, engine off and trans in neutral, turn one of the wheels forward, if the other one also turn forward then you have a sure grip. if it doesn't then you have an open rear.
Re: back wheels turning on jackstands [Re: Luigi] #2122915
08/01/16 09:34 PM
08/01/16 09:34 PM
AndyF Online content
AndyF  Online Content
That is normal, most cars are only one wheel drive. Limited slip was a performance option.
Re: back wheels turning on jackstands [Re: Luigi] #2123200
08/02/16 08:03 AM
08/02/16 08:03 AM
The Netherlands
Luigi Offline OP
Luigi  Offline OP
The Netherlands
Ok thanks. I knew that when turning one wheel by hand, the other one turns the opposite direction or won't turn at all. I thought this would be the same when the wheels were powered by the engine but apparently this isn't.
Back to my problem: heating brakedrums...
Luigi
