331 valves #2120974
07/29/16 11:03 PM
07/29/16 11:03 PM
K
Kip Offline OP
Kip  Offline OP
K
I have a ’54 331 in my ’27 T roadster. Right now it is pretty much stock, but over the winter I hope to rebuild it. I have found a few places that will do the machining and one of them tells me that the engine was originally built with hardened valve seats. Anyone here know anything about this ??
Re: 331 valves [Re: Kip] #2121002
07/29/16 11:56 PM
07/29/16 11:56 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
i have been told the same thing by a guy that was sold a job by machinist---machinist claimed he put in the hardened seats and it was later discovered he only cut the existing ones.....sounds like you found a good machinist.....
Re: 331 valves [Re: Kip] #2121126
07/30/16 08:58 AM
07/30/16 08:58 AM
AZ
Mike P Offline
Mike P  Offline
AZ
All the first gen HEMIs I've had apart have had factory installed hardened exhaust seats.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold
1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold
1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 331 valves [Re: Mike P] #2121297
07/30/16 02:14 PM
07/30/16 02:14 PM
K
Kip Offline OP
Kip  Offline OP
K
OK... Thanks for the information. How do you tell if the seats are hardened ??
Re: 331 valves [Re: Kip] #2121349
07/30/16 03:28 PM
07/30/16 03:28 PM
AZ
Mike P Offline
Mike P  Offline
AZ
The hardened seat is a separate piece that is pressed into the head (Upper seat in picture) instead of being ground directly into the head like the lower (intake) seat. It’s pretty easy to tell once you get the valves out.
Speaking of valves most (all?) of the first gen HEMIs used sodium filled exhaust valves. Basically the valve was made in 2 pieces (head and stem) and welded together. Any pitting in the weld area just under the valve head pretty much renders the valve unsafe to use.
Re: 331 valves [Re: Mike P] #2121431
07/30/16 06:20 PM
07/30/16 06:20 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory parts catalog shows the exhaust seat (9-39-9) used up through the '58 392.
Re: 331 valves [Re: Kip] #2121878
07/31/16 01:19 PM
07/31/16 01:19 PM
Peoples Republic of Oregon
W
wayfarer Offline
wayfarer  Offline
W
...sadly, there is some mis-information posted here.
The ONLY sodium filled valve is from the truck engines and easy to spot since they had stem od in the 0.4375" range.
Although the hardened insert was used and shows in the parts catalogue MaMopar also used INDUCTION hardened seats on many engines. These will be evident after cleaning since there will be heat discoloration.
www.qualityengineeredcomponents.com
Early Hemi Parts and Tech
EarlyHemi and flat 6&8 trans adapters
***inventory clearance in progress. Nothing held back. See website.***
Re: 331 valves [Re: Kip] #2125300
08/04/16 11:18 PM
08/04/16 11:18 PM
K
Kip Offline OP
Kip  Offline OP
K
Thanks guys, for all of the info
Kip
