Re: 331 valves
[Re: Kip]
#2121002
07/29/16 11:56 PM
07/29/16 11:56 PM
Posts: 2,042 colorado
savoy64
colorado
i have been told the same thing by a guy that was sold a job by machinist---machinist claimed he put in the hardened seats and it was later discovered he only cut the existing ones.....sounds like you found a good machinist.....
Re: 331 valves
[Re: Kip]
#2121126
07/30/16 08:58 AM
07/30/16 08:58 AM
Posts: 1,511 AZ
Mike P
AZ
All the first gen HEMIs I've had apart have had factory installed hardened exhaust seats.
1957 Plymouth (Hemi, Dual Quads, A833 4 Speed 9 1/4 w 4.10) Sold 1937 Dodge Pickup (Hemi, 6X2 intake, 46RH, Dana 60 w 4.56) Sold 1968 Plymouth Valiant 2dr sedan (354 HEMI, 46RH w/4.30 gears)
Re: 331 valves
[Re: Kip]
#2121349
07/30/16 03:28 PM
07/30/16 03:28 PM
Posts: 1,511 AZ
Mike P
AZ
The hardened seat is a separate piece that is pressed into the head (Upper seat in picture) instead of being ground directly into the head like the lower (intake) seat. It’s pretty easy to tell once you get the valves out. Speaking of valves most (all?) of the first gen HEMIs used sodium filled exhaust valves. Basically the valve was made in 2 pieces (head and stem) and welded together. Any pitting in the weld area just under the valve head pretty much renders the valve unsafe to use.
Re: 331 valves
[Re: Mike P]
#2121431
07/30/16 06:20 PM
07/30/16 06:20 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The factory parts catalog shows the exhaust seat (9-39-9) used up through the '58 392.
