Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117390
07/25/16 03:58 PM
07/25/16 03:58 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I made one that is sort of like tool #1 out of scrap I had laying around.
I think the base was some 2" square tube 1/2" all thread as the post.
The top is also square tubing, maybe 1-1/4" or 1-1/2"? with a hole on each end, then some round tubes (to press the retainer down) that were put into the holes of the square tube and welded so they can't move. The footprint of the tubes pressing on the retainer is fairly small, like what would happen with "C" clamps, but worked that way. I "improved" it by welding some curved pipe sections to the tubes.
Large "C" clamps will work too, but you need a flat plate on the bottom
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117392
07/25/16 04:03 PM
07/25/16 04:03 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Yes, use to use half of a muffler clamp and the press
Then made a tool using the same muffler clamp and a center bolt and some washers, lot like the factory tool.
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Tools to remove snap ring on 727 clutch drum [Re: 70AARcuda] #2117431
07/25/16 05:13 PM
07/25/16 05:13 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
Originally Posted By 70AARcuda
Originally Posted By 62maxwgn
Was fortunate to acquire the original Miller tool years ago.
Got one of those off ebay 12 yrs ago...for 50 bucks.
Wow,that Miller Tool looked mighty familiar, once i saw a picture of it.
Went and opened up a couple of storage containers, and come to find, i have one of them, too.
Also used to collect, buy, Miller Tools, back in the old days.
This one of mine has to be NOS, as i never used it, as i have the other tool, that i used all the time.
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2117570
07/25/16 08:29 PM
07/25/16 08:29 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine, had it awhile
Re: Tools to remove snap ring on 727 clutch drum [Re: cudaman1969] #2119619
07/28/16 04:25 AM
07/28/16 04:25 AM
Maryland
MoparMike1974 Offline
Maryland
Originally Posted By cudaman1969
Mine, had it awhile
I have this one above and it works really well. Picked it up at carlisle 10+ years ago.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2119649
07/28/16 09:17 AM
07/28/16 09:17 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Here's mine.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2119652
07/28/16 09:22 AM
07/28/16 09:22 AM
Tacoma, Washington USA
Adam71Charger Offline
cOOL TOOLS!
Curious though, how many of you reuse the snap rings? Not saying its bad or good, just when you take the time to remove a tranny, and rebuild/repair, do you guys reuse snap rings? arent they fairly cheap to just buy new?
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2119670
07/28/16 10:00 AM
07/28/16 10:00 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
How many snap ring failures have you seen?
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2119695
07/28/16 10:55 AM
07/28/16 10:55 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Originally Posted By Adam71Charger
cOOL TOOLS!
As far as re using,sometimes yes and sometimes no.The main reason to change the snap ring is to get the correct clearance between the pressure plate and snap ring if you change disc's.
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2119716
07/28/16 11:24 AM
07/28/16 11:24 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
cOOL TOOLS!
it all depends on which they are and how they look. The one being talked about in this thread using the tools shown to aid their removal don't see a lot of abuse, and very little pressures, so there is no reason to change it unless it is damaged.
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2119757
07/28/16 12:16 PM
07/28/16 12:16 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
cOOL TOOLS!
If you use the proper tool to depress the clutch spring retainer, it makes it much easier to remove the snapring.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: Tools to remove snap ring on 727 clutch drum [Re: cudaman1969] #2119806
07/28/16 01:43 PM
07/28/16 01:43 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Mine, had it awhile
https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/248867/filename/image.jpeg
Same one in my garage.
It gets the job done.
I have mechanical Aptitude.
I can screw up anything.
Re: Tools to remove snap ring on 727 clutch drum [Re: bboogieart] #2119840
07/28/16 02:27 PM
07/28/16 02:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Mine, had it awhile
Works on other trans beside mopar.
As far as changing snap ring, the ring could brake and the tangs on the retainer will hold it anyway, never seen a reason to change one in all my years.
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2119912
07/28/16 04:12 PM
07/28/16 04:12 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
cOOL TOOLS!
The snap rings on the front clutch spring retainers can't pop off when correctly installed, there are tabs on the retainer to keep the snap ring in place and I've never seen one break.
Re: Tools to remove snap ring on 727 clutch drum [Re: SlickRS23] #2121605
07/30/16 11:26 PM
07/30/16 11:26 PM
Chicagoland 'Burbs
SlickRS23 Offline OP
Chicagoland 'Burbs
Thanks for all the replies, I learned a lot.
I ended up purchasing this one:
Tool #1
For $23.00 shipped it actually worked very well for a Chinese tool.
After I deburred the bottoms of the legs so all 4 would sit flush, Cleaned up the threads on the ends of the rod and cleaned up the threads in the base, it worked very well.
I don,t have a clue what the wing nut is for as I used a wrench.
Just thought I would share my results with you guys.
Thanks, Jeff
Re: Tools to remove snap ring on 727 clutch drum [Re: Adam71Charger] #2121620
07/30/16 11:39 PM
07/30/16 11:39 PM
Chicagoland 'Burbs
Chicagoland 'Burbs
cOOL TOOLS!
Hanging around the maintenance guys at work, one guy told me that a snap ring like this should fit snug in the groove.
The I.D. of the snap ring is slightly smaller then the O.D. it sits on.
Before I assembled my drum I test fit the snap ring. It should turn by hand with a slight resistance. If it spins freely or moves side to side or is bent, it should be replaced.
Same with the snap rings on the output shaft for the governor and bearing and the selective thickness snap ring on the front of the output shaft.
Jeff
