want to change 74 cuda front and back bumpers #211952
02/02/09 03:52 PM
02/02/09 03:52 PM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
my front and back bumpers have the big ugly black rubber on them and i like the look of 1970-71 any suggestions would i have to buy all new brackets
Re: want to change 74 cuda front and back bumpers [Re: jbcuda] #211953
02/02/09 03:54 PM
02/02/09 03:54 PM
WV.
Challenger_Nut Offline
WV.
Yes, That would be the easiest way. You can take the black extensions off but you need the brackets to pull the bumpers tight to the body.
Re: want to change 74 cuda front and back bumpers [Re: Challenger_Nut] #211954
02/02/09 04:24 PM
02/02/09 04:24 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
AND different bumpers
Re: want to change 74 cuda front and back bumpers [Re: jbcuda] #211955
02/02/09 04:56 PM
02/02/09 04:56 PM
Kelowna, B.C. Canada
DPelletier Offline
DPelletier  Offline
Us Mopar guys are lucky; by 1974 all the GM stuff had huge ugly 5mph bumpers whereas visually the Mopars made out much better other than the big blocky bumperettes.
My advice is to just remove the bumperettes and leave the rest alone: it looks fine IMO
1970 Super Bee 440 Six Pack 1974 'Cuda 2008 Ram 3500 Diesel 2006 Ram 3500 Diesel 2004.5 Ram 2500 Diesel 2003 Ram 3500 Diesel 2006 Durango Limited [url] http://1970superbee.piczo.com [/url]
Re: want to change 74 cuda front and back bumpers [Re: DPelletier] #211956
02/02/09 05:08 PM
02/02/09 05:08 PM
bristol tn
jbcuda Offline OP
jbcuda  Offline OP
bristol tn
that looks good enough for me
wouldnt happen to have pic of rear
Re: want to change 74 cuda front and back bumpers [Re: jbcuda] #211957
02/02/09 05:17 PM
02/02/09 05:17 PM
DPelletier Offline
DPelletier  Offline
No that one isn't mine; mine still has the ugly rubber pces;
Re: want to change 74 cuda front and back bumpers [Re: DPelletier] #211958
02/02/09 05:22 PM
02/02/09 05:22 PM
DPelletier Offline
DPelletier  Offline
Just remember; It could always be worse!!
Re: want to change 74 cuda front and back bumpers [Re: DPelletier] #211959
02/02/09 05:34 PM
02/02/09 05:34 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I haven't seen I Camaro like that in ages, I thought it was an AMC Matador or Ambassador.
Re: want to change 74 cuda front and back bumpers [Re: boydsdodge] #211960
02/03/09 01:55 PM
02/03/09 01:55 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
There is a post on this in the "restoration" section. Do a search for it. Someone showed pictures of how he modified his front bumper brackets. It was as easy as drilling out one hole. The rear is a little more difficult. Either buy 70-71 rear bumper brackets or you have to cut and weld the existing brackets to work. Also check out the "member projects" section. There are some great pics of bumpers that have been moved in. Personally I like the look of the rubber bumpers. What I'm going to do is move the bumpers in next to the body, but keep the rubber extensions.
