Re: AV-GAS QUESTIONS................
[Re: Thumperdart]
#2118431
07/26/16 08:38 PM
07/26/16 08:38 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
A friend I met at the local College is now an airplane mechanic and sez I can buy all of the 100ll I want legally at $3.85-$4.00 per gallon instead of the $8.79 VP-101 so time to check it out. I know leaded can tolerate more timing but is there anything else I need to know?.............Thankxxx............ 100 low Lead Avaition has lead in it, the Federal Goverment fine for running leaded gas on the streets is $10,00.00 for each conviction Lots of the local street racers up here run it, none of them have been busted, YET I use to use it in my old bracket cars and NHRA stocker until I saw that it was eating up the valve seats It has a brake specific of .690 usually which means it will run real lean in most carbs without jetting or tuning BTW, more than one VTVL street guys made comments on my old street cars when I ran that fuel on the streets down there, they could smell it
[Re: Cab_Burge]
#2118434
07/26/16 08:40 PM
07/26/16 08:40 PM
Thumperdart
State of confusion
What's the difference between our seats and airplane seats........
[Re: Thumperdart]
#2118454
07/26/16 08:50 PM
07/26/16 08:50 PM
Cab_Burge
I really have no idea on the seat materials other than most airplane motors are air cooled and run under 2700 RPM The sleeves are steel and the block and heads are aluminum I had one exhaust valve spit a pie shape chunk out of my airplane motor at 8500 ft at 190 MPH about 50 miles east of Needles, CA, that made me turn around and go back to the Prescott, AZ airport real quickly. I had been running that mixtured at +25F rich of peak on the single probe EGT up to then, I ran it +75 F after that
[Re: Thumperdart]
#2118480
07/26/16 09:14 PM
07/26/16 09:14 PM
Posts: 7,506 Az
Crizila
Az
Reeds vapor pressure is the first thing that comes to my mind with AV gas. Discluding octane and lead issues, the stuff is ment to be run at altitude, not sea level. Airplane engines and what we race are very different in design. They run valve seats 2-3 times as wide as we do with spring pressures well under what we run.
Fastest 300
[Re: Thumperdart]
#2118483
07/26/16 09:18 PM
07/26/16 09:18 PM
Posts: 685 pennsylvania
poboyengineering
pennsylvania
could one pick up a couple of points of octane with a 50/50 mix of avgas and 93 E10 and solve both the vapor lock issue with the pump stuff and the vaporization pressure issue with the avgas?
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
[Re: Crizila]
#2118512
07/26/16 09:43 PM
07/26/16 09:43 PM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
Reeds vapor pressure is the first thing that comes to my mind with AV gas. Discluding octane and lead issues, the stuff is ment to be run at altitude, not sea level. Airplane engines and what we race are very different in design. They run valve seats 2-3 times as wide as we do with spring pressures well under what we run. I guess airplanes dont take off at sea level. This is where they need the power.
[Re: Crizila]
#2118516
07/26/16 09:45 PM
07/26/16 09:45 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Reeds vapor pressure is the first thing that comes to my mind with AV gas. Discluding octane and lead issues, the stuff is ment to be run at altitude, not sea level. Airplane engines and what we race are very different in design. They run valve seats 2-3 times as wide as we do with spring pressures well under what we run. Bing-go.... yes guys run it on the street but usually with lower compression thinking its better... hard seats can use the no lead... if you need lead... you better add it
[Re: Dodgeguy101]
#2118528
07/26/16 09:51 PM
07/26/16 09:51 PM
Cab_Burge
Reeds vapor pressure is the first thing that comes to my mind with AV gas. Discluding octane and lead issues, the stuff is ment to be run at altitude, not sea level. Airplane engines and what we race are very different in design. They run valve seats 2-3 times as wide as we do with spring pressures well under what we run. I guess airplanes dont take off at sea level. This is where they need the power. Take off at sea level is no big deal in many piston powered airplanes, taking off at Denver in the summer in the middle of the day is a little more challenging You have to lean the motor out for best power on the run up and know that the airplane will take around another 1500 to 3000 ft more on the take off roll to get airborne and then fly like a lame slug in that air density, keep the nose down and get some speed up before manuevering I flew into and out of Denver once, I told the passengers to be ready for takeoff before 9:00 AM, which they where The air density was still way above 10,000 at that time That engine was a 540 C.I. Lycoming opposed six cyliner rated at 260HP at sea level., it had around 170 HP max at that airport that day in that weather leaned out
[Re: Challenger 1]
#2118551
07/26/16 10:04 PM
07/26/16 10:04 PM
Thumperdart
State of confusion
Here we go..... Ever notice someone who posts a lot says nothing worth reading with a lot of emotions? Who might that be...........
[Re: Thumperdart]
#2118566
07/26/16 10:18 PM
07/26/16 10:18 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
low lead will still kill an o2 sensor.
[Re: CSK]
#2118636
07/26/16 11:21 PM
07/26/16 11:21 PM
Thumperdart
State of confusion
low lead will still kill an o2 sensor. I'm still on the same 02 from 6+ years ago and it`s fine............
[Re: Thumperdart]
#2118665
07/26/16 11:40 PM
07/26/16 11:40 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
low lead will still kill an o2 sensor. I'm still on the same 02 from 6+ years ago and it`s fine............ That might be, but O2 sensors were never designed to run with leaded fuels. The chances of fouling a sensor are pretty high on a street motor that might idle around a lot more than a race engine at temp.
[image][/image]
