70 E-Body Exhaust Hanger Trunk Plates #2117494
07/25/16 06:28 PM
07/25/16 06:28 PM
Indianapolis, IN
B5Cuda440-6 Offline OP
Indianapolis, IN
Does anyone make a close reproduction of the exhaust plates that mount on the trunk floor (using the small Phillips head screw) and are used to bolt the exhaust hanger insulators?
I've been trying to find a good original set with no luck.
Thanks everyone!
Rob
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2117496
07/25/16 06:31 PM
07/25/16 06:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Have you tried ECS, I know Dave makes a lot of small engine/body brackets and pieces, some not listed on his site, I would think with his repro OEM E body exhaust components he "might" offer these or have them in the works?
Mike
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2117573
07/25/16 08:36 PM
07/25/16 08:36 PM
Indianapolis, IN
Indianapolis, IN
Good idea, Mike. I just checked the ECS website and didn't see them. But he may not have them listed...I'll have to give them a call.
Hopefully Dave has them, because If he does they are probably the closest to OEM.
Rob
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2117684
07/25/16 10:30 PM
07/25/16 10:30 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Rob,
You know your car doesn't use the small screw, right? LA just glued them in. No screw.
Chris
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2118025
07/26/16 12:25 PM
07/26/16 12:25 PM
Indianapolis, IN
Indianapolis, IN
No, I was not aware of that. My car currently has a screw, but I'm not sure if it was added when it was restored.
Do you have a picture of an LA car with the plate installed without the screw? Did they just fill-in the screw hole with glue?
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2119658
07/28/16 09:31 AM
07/28/16 09:31 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
That might be something that was done wrong on your car. There was a post on here a long time ago about differences between LA cars and other plants and that was highlighted.
I can check my one sole LA car but it's more of a parts car. Send me an email
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2119663
07/28/16 09:43 AM
07/28/16 09:43 AM
Indianapolis, IN
Indianapolis, IN
Thanks, Chris. E-mail sent.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2119686
07/28/16 10:39 AM
07/28/16 10:39 AM
Maryland
glenngomango Offline
Maryland
Rob- I believe Frank Badalson in Richmond ,VA has the hangers.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2119743
07/28/16 12:01 PM
07/28/16 12:01 PM
Indianapolis, IN
Indianapolis, IN
Thanks...I'll give him a call as well.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2120479
07/29/16 11:07 AM
07/29/16 11:07 AM
ronj Offline
ronj  Offline
Dale's Cuda Shop Ohio has them
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2121398
07/30/16 04:54 PM
07/30/16 04:54 PM
Sacramento,California
JRepucci Offline
JRepucci  Offline
No screws on 121177
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: JRepucci] #2121411
07/30/16 05:20 PM
07/30/16 05:20 PM
imperial mo.
stickman Offline
stickman  Offline
imperial mo.
accurate exhaust sells the plates also.
YOU CAN`T RUN WITH THE BIG DOGS IF YOU NEVER LEAVE THE PORCH.
EB5 70 U Code RT/SE Shaker Challenger
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2121474
07/30/16 07:29 PM
07/30/16 07:29 PM
Indianapolis, IN
Indianapolis, IN
Thanks for the info everyone, and the pic, Jason.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2129731
08/10/16 07:25 PM
08/10/16 07:25 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Here is an LA car and you can see that it never had a screw. The screw hole is filled with buddy. LA glued these in good
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2129780
08/10/16 08:52 PM
08/10/16 08:52 PM
Indianapolis, IN
Indianapolis, IN
I see exactly what you mean, Chris. Based on what you and Jason have said/shown, I won't be re-installing them with the screw. Any idea of what type of glue or putty they used?
I cleaned-up my hangers and I only need 1 clean original to replace one that is really badly pitted. For some reason, one of mine is perfect, while the other is toast. I’m going to keep searching for an original before I buy a pair of reproduction hangers.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2129795
08/10/16 09:10 PM
08/10/16 09:10 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It's real hard to find a good original with the trunk mats that Chrysler used.
Re: 70 E-Body Exhaust Hanger Trunk Plates [Re: B5Cuda440-6] #2129804
08/10/16 09:21 PM
08/10/16 09:21 PM
Indianapolis, IN
Indianapolis, IN
I can imagine. The moisture collects under the mats and just sits there corroding the metal. Hopefully I'll come across one...
