What starter with Indy block? #211662
02/02/09 09:57 AM
02/02/09 09:57 AM
Oklahoma
silverfish Offline OP
Oklahoma
I know this has probably been hashed out before but....what starter are you guys using with the Indy Max block. I'm having problems getting one to fit because of the extra ribs that this block has versus the factory block. I have a RobbMC starter and it won't fit. It has to be a powerful starter too because this is a high compression big inch race only motor. Header clearance is not an issue b/c its on a tube chassis car. What has everyone else had good luck with???
Re: What starter with Indy block? [Re: silverfish] #211663
02/02/09 11:19 AM
02/02/09 11:19 AM
an8sec70cuda Offline
Not sure on the Indy block, but I have the MP mini starter on my KB block w/ no clearance issues. My 572" is only 11:1 but I had it on a 14.5:1 446" and it spun it over no problem also. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What starter with Indy block? [Re: an8sec70cuda] #211664
02/02/09 12:03 PM
02/02/09 12:03 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Mini mopar on all ours.
Re: What starter with Indy block? [Re: B G Racing] #211665
02/02/09 12:11 PM
02/02/09 12:11 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Factory Mini starters here 560 inch mill with near 16:1 compression.
Re: What starter with Indy block? [Re: Bob_Coomer] #211666
02/02/09 12:28 PM
02/02/09 12:28 PM
Oklahoma
Oklahoma
I just haven't had very good luck with Mopar minis in the past but I guess thats what I'll go with because nothing else seems to fit the aftermarket blocks. Thanks for the info guys!
Re: What starter with Indy block? [Re: silverfish] #211667
02/02/09 01:19 PM
02/02/09 01:19 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I use the Mopar mini starter with 15-1 CR no problems so far.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: What starter with Indy block? [Re: silverfish] #211668
02/02/09 02:13 PM
02/02/09 02:13 PM
Big camshafts with a lot of overlap don't usually make very much cranking compression, most stock starters work fine on my high compression motors (14.7 to 1 on the last one)with tight LSA(106)
Re: What starter with Indy block? [Re: silverfish] #211669
02/02/09 10:19 PM
02/02/09 10:19 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
got a indy max block run a mini starter from a 92 full size truck longer case more power starts my 572 with 16.5to1 just fine no issues its tight but fits with no mods
Re: What starter with Indy block? [Re: bad1970dust] #211670
02/02/09 10:30 PM
02/02/09 10:30 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I use a mini starter, tried to use one of those fancy CSR billet nose super duper ones from them
Ahh, no workie ,,look how much longer
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: What starter with Indy block? [Re: bigdad] #211671
02/02/09 10:34 PM
02/02/09 10:34 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
stock truck starter, 15 to 1
Re: What starter with Indy block? [Re: rtstreet] #211672
02/02/09 10:40 PM
02/02/09 10:40 PM
by far the best starter i have used is a MEZIERE
TS104. ive got 14.8 compression.
Re: What starter with Indy block? #211673
02/03/09 03:09 AM
02/03/09 03:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
even a 440 source starter fits a maxx block. i keep one as a spare for emergencies.
