Bent torsion bars #2115078
07/21/16 08:41 PM
07/21/16 08:41 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Is it normal for torsion bars to have a slight bend? Are they perfectly straight from the factory? Heres a pic of mine.
Re: Bent torsion bars [Re: Hot 340] #2115097
07/21/16 09:13 PM
07/21/16 09:13 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Are you leaning on it? grin
Don't know , never seen this question before. bump
Re: Bent torsion bars [Re: Hot 340] #2115102
07/21/16 09:21 PM
07/21/16 09:21 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I've seen a couple over the years have a slight arch to them. I don't think it has ever hindered their performance. Is the adjustment the same left to right?
[image][/image]
Re: Bent torsion bars [Re: Hot 340] #2115113
07/21/16 09:33 PM
07/21/16 09:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats common on bars that have been in there for
a few years
wave
Re: Bent torsion bars [Re: MR_P_BODY] #2115116
07/21/16 09:36 PM
07/21/16 09:36 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Does use or abuse cause them to bend?
Re: Bent torsion bars [Re: Hot 340] #2115197
07/21/16 11:05 PM
07/21/16 11:05 PM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
I bowed one pretty good launching a 340/stick Swinger at 6000 on slicks w/o subframe connectors. boogie
Re: Bent torsion bars [Re: jcc] #2115203
07/21/16 11:12 PM
07/21/16 11:12 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I aint that heavy! biggrin
Re: Bent torsion bars [Re: sgcuda] #2115204
07/21/16 11:13 PM
07/21/16 11:13 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Well, they both a slight arch to them.
Re: Bent torsion bars [Re: Hot 340] #2115237
07/22/16 12:12 AM
07/22/16 12:12 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I have a set in my attic and you can have them since you offered me some free head gaskets. I think they are the six cylinder ones or something that guys switch to. Let me know
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bent torsion bars [Re: pittsburghracer] #2115339
07/22/16 07:21 AM
07/22/16 07:21 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Thanks John. I appreciate the offer. Id like to stick with these if i can because these are thicker 340 bars and work decent for a street driver. If it was race only id use the six bars from ya. up
Re: Bent torsion bars [Re: jcc] #2115396
07/22/16 11:17 AM
07/22/16 11:17 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Not really... just being wound up all the time... if you
bottom out a lot it adds to it... but being a spring and
twisting them they tend to move around... I seen plenty
of them like that when I was on the transverse T-bar project
when I was building up the mule cars(taking all the stock
stuff off the cars to set them up for our stuff)
wave
Re: Bent torsion bars [Re: Hot 340] #2115415
07/22/16 11:41 AM
07/22/16 11:41 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I used to own a 95 Dakota 4x4 5-speed. I was told a previous owner used it as a field truck.(farmer) Someone must have tried driving over a stump/large rock because the torsion bar x-member was badly damaged. The x-member was bent...pushed back. Both torsion bars had a noticeable bend in them. They still functioned and didn't break.
Re: Bent torsion bars [Re: Hot 340] #2115619
07/22/16 04:30 PM
07/22/16 04:30 PM
my own world
theraif Offline
theraif  Offline
my own world
after a night of racing drove my 71 home like any other night , went out sunday morning and was what the .....looked and the t-bar was broke
Re: Bent torsion bars [Re: Hot 340] #2115694
07/22/16 06:54 PM
07/22/16 06:54 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I can't figure how those bars would ever get bent. They are mounted on an even plane and rotate on the same plane. Even sitting, there isn't any weight or force that should cause them to bend. My car sat for over 30 years and the bars haven't bent.
That said, I bought a "set" from a member on here a few years ago and one was bent. Checking the numbers, they were both for the same side. I can only guess that the one that was bent had been installed on the wrong side and that caused the bend.
Re: Bent torsion bars [Re: Stanton] #2115703
07/22/16 07:11 PM
07/22/16 07:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ONLY difference is the way they are PRE loaded... we would
wind up the bars to get a pre known set to them.... they all
started out the same... the hexes were all the same.. when you
pre load them they in up with a set... that would dictate which
bar went on what side of the car... thats all there was to it..
and I seen them have them have a slight bend in them new... it
didnt matter at all
EDIT
The reason for the pre load was for warranty.. without
the preload the cars would settle lower after a short
period of time... so we started pre loading all the bars
wave
Re: Bent torsion bars [Re: MR_P_BODY] #2115877
07/22/16 11:16 PM
07/22/16 11:16 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Just went out and looked at a set of /6 .830 bars I have and a set of .870 340 bars I took out of my dart. Both sets are preloaded, but I didn't see any bows in them.
