Re: Bent torsion bars
[Re: Hot 340]
#2115102
07/21/16 09:21 PM
07/21/16 09:21 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I've seen a couple over the years have a slight arch to them. I don't think it has ever hindered their performance. Is the adjustment the same left to right?
[image][/image]
[Re: MR_P_BODY]
#2115116
07/21/16 09:36 PM
07/21/16 09:36 PM
Posts: 22,695 Bitopia
jcc
Bitopia
Does use or abuse cause them to bend?
[Re: sgcuda]
#2115204
07/21/16 11:13 PM
07/21/16 11:13 PM
Posts: 3,391 Pa
Hot 340
Pa
I've seen a couple over the years have a slight arch to them. I don't think it has ever hindered their performance. Is the adjustment the same left to right? Well, they both a slight arch to them.
[Re: Hot 340]
#2115237
07/22/16 12:12 AM
07/22/16 12:12 AM
Posts: 20,116 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I have a set in my attic and you can have them since you offered me some free head gaskets. I think they are the six cylinder ones or something that guys switch to. Let me know
[Re: jcc]
#2115396
07/22/16 11:17 AM
07/22/16 11:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Does use or abuse cause them to bend? Not really... just being wound up all the time... if you bottom out a lot it adds to it... but being a spring and twisting them they tend to move around... I seen plenty of them like that when I was on the transverse T-bar project when I was building up the mule cars(taking all the stock stuff off the cars to set them up for our stuff)
[Re: Stanton]
#2115703
07/22/16 07:11 PM
07/22/16 07:11 PM
MR_P_BODY
I can't figure how those bars would ever get bent. They are mounted on an even plane and rotate on the same plane. Even sitting, there isn't any weight or force that should cause them to bend. My car sat for over 30 years and the bars haven't bent.
That said, I bought a "set" from a member on here a few years ago and one was bent. Checking the numbers, they were both for the same side. I can only guess that the one that was bent had been installed on the wrong side and that caused the bend. The ONLY difference is the way they are PRE loaded... we would wind up the bars to get a pre known set to them.... they all started out the same... the hexes were all the same.. when you pre load them they in up with a set... that would dictate which bar went on what side of the car... thats all there was to it.. and I seen them have them have a slight bend in them new... it didnt matter at all EDIT The reason for the pre load was for warranty.. without the preload the cars would settle lower after a short period of time... so we started pre loading all the bars
