Track update for the c barge:new best #211554
02/02/09 12:15 AM
02/02/09 12:15 AM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I took the Polara back to the track today.Made a few runs with the 1 7/8 tti headers installed(hooker 1 3/4 super comps before).Lost .05 on my 60ft. and 2 mph up top.There was a signifigant headwind not present at last outing.Otherwise weather conditions were identical.
Felt like my cold air setup might be restrictive so I replaced the air cleaner lid with one that covers the top of the filter and leaves the rest open with my cold air tubes still hooked up to the base.BAM matched my best time previously and mph 12.70 @ 106.Swapped my modified 750 vacuum secondary for my BIGS 850dp and knocked down two new bests with the open lid still in place.12.59 @ 106 and then a 12.54 @ 107 with a steady 15-20 mph headwind.
On my best et I spun out of the hole but still got my best 60ft of 1.79 and a 7.98 1/8 @ 87mph.On the 12.59 I dead hooked and it bogged a little.
I wish I had tried the larger carb and open lid with the old headers(like WIZE told me to).The larger headers(which I convinced myself were better for a 496 even at my weight)seemed to move the tq band up a little.I could use some more stall speed to compensate( I found one of my flexplate bolts missing and the others loose before I left.Could not get the new bolt to tighten so I rednecked it and tightened the other 3 and went racing )
I don't even know where the timing is at.I may schedule some dyno tuning to check timing/jetting for max hp and tq.
I need to redo my cold/fresh air setup with some larger tubes so it can breathe.
Maybe some N2O will get me the 11 sec slip
Sorry for the long post.
George
Re: Track update for the c barge:new best [Re: gch] #211555
02/02/09 12:22 AM
02/02/09 12:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Good job at least your out there testing
Re: Track update for the c barge:new best [Re: MR_P_BODY] #211556
02/02/09 12:26 AM
02/02/09 12:26 AM
Salina ks
572_dup2 Offline
Back On The Bumper!!
572_dup2  Offline
Salina ks
Good job Your giving your best
Shawn Jennings
Re: Track update for the c barge:new best [Re: 572_dup2] #211557
02/02/09 02:25 AM
02/02/09 02:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
You got that thing running great ! Congrats on the new best. Ron
Re: Track update for the c barge:new best [Re: 383man] #211558
02/02/09 12:39 PM
02/02/09 12:39 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
What's it weigh? You give me cause for hope with my NYker.
Kevin
Re: Track update for the c barge:new best [Re: gch] #211559
02/02/09 01:41 PM
02/02/09 01:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s great..........Aren`t new bests cool?
Re: Track update for the c barge:new best [Re: gch] #211560
02/02/09 01:51 PM
02/02/09 01:51 PM
an8sec70cuda Online content
an8sec70cuda  Online Content
Congrats George!! That has to be fun goin that fast in such a big car, must surprise a lot of people!! I want to see that thing in person...you going to rockingham this year? CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Track update for the c barge:new best [Re: an8sec70cuda] #211561
02/02/09 07:24 PM
02/02/09 07:24 PM
west palm beach, florida
modelmakerinc Offline
for those of us interested but do not know your car, could you please post some specs on it and or pictures.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Track update for the c barge:new best [Re: Twostick] #211562
02/02/09 07:31 PM
02/02/09 07:31 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Kevin
I havent weighed it in a couple of years.IIRC it was 4400lbs plus my 220 so I am getting up there.
Re: Track update for the c barge:new best [Re: modelmakerinc] #211563
02/02/09 07:42 PM
02/02/09 07:42 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
I will have to work on pics.All of mine are too large to post and I am a computer dummy.I can send them to someone to resize and post.
Chip,Don't know if I will drive it to Rockingham or not.If you ever come up to Fayeeteville let me know.
Quick spec sheet:
496 c.i.
4.15 eagle crank w/main studs
9.2-1 KB pistons
stock rods w/arp bolts
KB pistons with big quench dome(but down in the hole)
Hughes solid cam 237/242 @ .050
ported 346 heads by Hensley 2.14x1.81
milled to 78cc
hughes 1.6 rockers
rollmaster chain
ch4b intake port matched by Hughes
750 vac sec(street)850 dp(race)
TCI street fighter 727(30k miles and counting)
SMR 11" converter(built for my 440 and needs freshening/tightening)
3.55 sure grip
275/60/15 nitto drag radials
1 7/8 tti headers
3" to x-pipe and 2.5 back with dynomax long case super turbo mufflers.
Alot of this stuff was on my 440 and may not be ideal smallish works well for the weight of the car.
Re: Track update for the c barge:new best [Re: gch] #211564
02/02/09 08:04 PM
02/02/09 08:04 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Send them to me, I'll size and post or help either way, let me know
Good job on the car, love see big / fast MOPARS !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Track update for the c barge:new best [Re: bigdad] #211565
02/02/09 08:27 PM
02/02/09 08:27 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
send me your email and I will attach them.Thanks!
gch99@embarqmail.com
Re: Track update for the c barge:new best [Re: gch] #211566
02/02/09 08:28 PM
02/02/09 08:28 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Congrats. Nothing like making changes and tuning to a new best.
Re: Track update for the c barge:new best [Re: BSB67] #211567
02/02/09 08:31 PM
02/02/09 08:31 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Yours is impressive to say the least.I pale in comparison.
I have about everything to go 505 or larger and would love to have similar reults with a stock converter and 3.23 gears.
Re: Track update for the c barge:new best [Re: gch] #211568
02/02/09 08:35 PM
02/02/09 08:35 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
should have email !
Re: Track update for the c barge:new best [Re: bigdad] #211569
02/02/09 08:57 PM
02/02/09 08:57 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Pics to come soon.Some were before the car was painted but you get the idea.
Re: Track update for the c barge:new best [Re: gch] #211570
02/02/09 09:10 PM
02/02/09 09:10 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Should be there, post away !
Re: Track update for the c barge:new best [Re: bigdad] #211571
02/02/09 09:14 PM
02/02/09 09:14 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
PICS
Re: Track update for the c barge:new best [Re: gch] #211572
02/02/09 09:15 PM
02/02/09 09:15 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
pic
Re: Track update for the c barge:new best [Re: gch] #211573
02/02/09 09:16 PM
02/02/09 09:16 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
front
