Track update for the c barge:new best
#211554
02/02/09 12:15 AM
02/02/09 12:15 AM
Posts: 3,152 Central NC
gch
Central NC
I took the Polara back to the track today.Made a few runs with the 1 7/8 tti headers installed(hooker 1 3/4 super comps before).Lost .05 on my 60ft. and 2 mph up top.There was a signifigant headwind not present at last outing.Otherwise weather conditions were identical. Felt like my cold air setup might be restrictive so I replaced the air cleaner lid with one that covers the top of the filter and leaves the rest open with my cold air tubes still hooked up to the base.BAM matched my best time previously and mph 12.70 @ 106.Swapped my modified 750 vacuum secondary for my BIGS 850dp and knocked down two new bests with the open lid still in place.12.59 @ 106 and then a 12.54 @ 107 with a steady 15-20 mph headwind. On my best et I spun out of the hole but still got my best 60ft of 1.79 and a 7.98 1/8 @ 87mph.On the 12.59 I dead hooked and it bogged a little. I wish I had tried the larger carb and open lid with the old headers(like WIZE told me to).The larger headers(which I convinced myself were better for a 496 even at my weight)seemed to move the tq band up a little.I could use some more stall speed to compensate( I found one of my flexplate bolts missing and the others loose before I left.Could not get the new bolt to tighten so I rednecked it and tightened the other 3 and went racing ![](/ubbthreads/images/graemlins/biggrin.gif) ) I don't even know where the timing is at.I may schedule some dyno tuning to check timing/jetting for max hp and tq. I need to redo my cold/fresh air setup with some larger tubes so it can breathe. Maybe some N2O will get me the 11 sec slip ![](/ubbthreads/images/graemlins/laugh2.gif) Sorry for the long post. George
Re: Track update for the c barge:new best
[Re: gch]
#211560
02/02/09 01:51 PM
02/02/09 01:51 PM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
Congrats George!! That has to be fun goin that fast in such a big car, must surprise a lot of people!! ![](/ubbthreads/images/graemlins/beer.gif) I want to see that thing in person...you going to rockingham this year? ![](/ubbthreads/images/graemlins/1343795-scratchchin.gif) CHIP
[Re: Twostick]
#211562
02/02/09 07:31 PM
02/02/09 07:31 PM
gch
Central NC
What's it weigh? You give me cause for hope with my NYker.
Kevin
I havent weighed it in a couple of years.IIRC it was 4400lbs plus my 220 so I am getting up there.
[Re: modelmakerinc]
#211563
02/02/09 07:42 PM
02/02/09 07:42 PM
gch
Central NC
for those of us interested but do not know your car, could you please post some specs on it and or pictures.
I will have to work on pics.All of mine are too large to post and I am a computer dummy.I can send them to someone to resize and post. Chip,Don't know if I will drive it to Rockingham or not.If you ever come up to Fayeeteville let me know. Quick spec sheet: 496 c.i. 4.15 eagle crank w/main studs 9.2-1 KB pistons stock rods w/arp bolts KB pistons with big quench dome(but down in the hole) Hughes solid cam 237/242 @ .050 ported 346 heads by Hensley 2.14x1.81 milled to 78cc hughes 1.6 rockers rollmaster chain ch4b intake port matched by Hughes 750 vac sec(street)850 dp(race) TCI street fighter 727(30k miles and counting) SMR 11" converter(built for my 440 and needs freshening/tightening) 3.55 sure grip 275/60/15 nitto drag radials 1 7/8 tti headers 3" to x-pipe and 2.5 back with dynomax long case super turbo mufflers. Alot of this stuff was on my 440 and may not be ideal smallish works well for the weight of the car.
[Re: gch]
#211564
02/02/09 08:04 PM
02/02/09 08:04 PM
Posts: 34,962 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Send them to me, I'll size and post or help either way, let me know
Good job on the car, love see big / fast MOPARS !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: BSB67]
#211567
02/02/09 08:31 PM
02/02/09 08:31 PM
gch
Central NC
Congrats. Nothing like making changes and tuning to a new best.
Yours is impressive to say the least.I pale in comparison. I have about everything to go 505 or larger and would love to have similar reults with a stock converter and 3.23 gears.
[Re: gch]
#211570
02/02/09 09:10 PM
02/02/09 09:10 PM
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Should be there, post away !
[Re: bigdad]
#211571
02/02/09 09:14 PM
02/02/09 09:14 PM
gch
Central NC
[Re: gch]
#211572
02/02/09 09:15 PM
02/02/09 09:15 PM
gch
Central NC
[Re: gch]
#211573
02/02/09 09:16 PM
02/02/09 09:16 PM
gch
Central NC
