In tank fuel pump #2114695
07/21/16 12:05 PM
07/21/16 12:05 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Has anyone installed a stock late model type fuel pump in an earlier tank? If so how much pressure and volume did you achieve? If enough I will use in a race car. I know I have to run a return line.
Re: In tank fuel pump [Re: cudaman1969] #2114894
07/21/16 03:54 PM
07/21/16 03:54 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Tanks inc
Re: In tank fuel pump [Re: cudaman1969] #2115193
07/21/16 11:03 PM
07/21/16 11:03 PM
fredericksburg,va
fredericksburg,va
Would like feedback from real world users. But I'll check those guys out.
Re: In tank fuel pump [Re: cudaman1969] #2115212
07/21/16 11:23 PM
07/21/16 11:23 PM
tucson az
frank Offline
frank  Offline
tucson az
I did this in my GTX using an Aeromotive Stealth 340 pump installed in the stock fuel tank. This is a simple task if you can fabricate and weld; if not then it is an expensive task. Pump output depends on pressure. The higher the pressure (fuel injection) the less output. Using a carb (5-10 PSI) the pump is almost at free flow therefore it will pump more fuel. You can get flow rates for any pump via a google search. I am doing my other cars fuel system now in preparation for a 512 stroker. I am going to use Tanks Inc. For about $500 you can get a new fuel tank with a sump box installed and fuel pump (they use Welbro) modified to be easily installed in the tank. All of this can be had at Summit for less than what you can get direct from Tanks Inc. (at least for my application)
Re: In tank fuel pump [Re: frank] #2115214
07/21/16 11:27 PM
07/21/16 11:27 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
iagree just put a tanks inc tank and EFI pump in my 69 Bee.
Re: In tank fuel pump [Re: Dabee] #2115231
07/22/16 12:00 AM
07/22/16 12:00 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
AEROMOTIVE ROCKS, Done a few in different cars, No problems, no issues, they just work. And their Support is AWESOME!
twocents
Re: In tank fuel pump [Re: TJP] #2115292
07/22/16 01:49 AM
07/22/16 01:49 AM
tucson az
frank Offline
frank  Offline
tucson az
I'm very happy with the Aeromotive Stealth 340 in the GTX. That car has a strong 496 and no fuel issues. I recommend it highly but it is much more expensive than the Walbro. Both are quality pumps in my opinion.
Re: In tank fuel pump [Re: Dabee] #2115294
07/22/16 01:49 AM
07/22/16 01:49 AM
5th and plum
redmist Offline
redmist  Offline
5th and plum
tanks inc Tank, Aeromotive 340 pump, and a Jakefab install kit/top hat makes for a very very nice baffled tank setup.
the Jakefab setup has 1/4" NPT inlet ports instead of 1/8" as found on the Aeromotive products.
I am Bias though.
Re: In tank fuel pump [Re: cudaman1969] #2115427
07/22/16 12:04 PM
07/22/16 12:04 PM
fredericksburg,va
fredericksburg,va
Do they make kit for a fuel cell?
