Are 68/69 Roadrunner doors different? #2114117
07/20/16 03:45 PM
07/20/16 03:45 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
I need to replace a passenger side door on my 68 Roadrunner. I found a nice 69 door locally but I need to know if there are any differences. Thanks!!
1970 Barracuda B5 6.1 Hemi/6 speed
1969 Charger survivor in R6 383/727-wrecked 12/24/18
1968 Charger in original burgundy paint "Ribeye"
1968 Charger w/ 6.1L, TR-6060, 9"
1968 Roadrunner w/ 6.1L/6 speed
2011 Dodge Ram w/ 6.7L
Re: Are 68/69 Roadrunner doors different? [Re: 70B5Cuda] #2114183
07/20/16 04:52 PM
07/20/16 04:52 PM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
I think the lock position is different and may be another thing, but can't recall right now.
Re: Are 68/69 Roadrunner doors different? [Re: MI_Custumz] #2114192
07/20/16 04:58 PM
07/20/16 04:58 PM
JERSEY
RJS Offline
RJS  Offline
JERSEY
Yep inner lock knob position
Re: Are 68/69 Roadrunner doors different? [Re: 70B5Cuda] #2114216
07/20/16 05:17 PM
07/20/16 05:17 PM
Ohio
dobie Offline
dobie  Offline
Ohio
Yup. Door lock knobs are in different spots.
1968 Plymouth Road Runner 383 4 speed
Re: Are 68/69 Roadrunner doors different? [Re: 70B5Cuda] #2114223
07/20/16 05:26 PM
07/20/16 05:26 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
All the lock mechanism inside the xoor is different
Re: Are 68/69 Roadrunner doors different? [Re: 70B5Cuda] #2114262
07/20/16 06:43 PM
07/20/16 06:43 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Along with the lock button location, which you can relocate if need be, having upper pads means no welding/body work if equipped?, you'll need to change out the glass and the rear glass tracks as they are different
Re: Are 68/69 Roadrunner doors different? [Re: DAYCLONA] #2114645
07/21/16 11:19 AM
07/21/16 11:19 AM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
Could you explain this? I'm not sure I understand.
Re: Are 68/69 Roadrunner doors different? [Re: 70B5Cuda] #2114664
07/21/16 11:41 AM
07/21/16 11:41 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
You'll need to drill a new hole for the rod lock knob to protruded thru the upper sill on the door, as the 68 is located in the rear, and 69-70 is more forward, if you have upper upholstered door pads there's no need to weld up the unused hole, other wise if your car has no pads, you'll need to weld/body work the upper inner portion of the door panel
The 68 glass has a narrower glass runner than the 69-79, also the rear stainless rear trim on the side glass is different in shape/profile, assuming we are talking hardtop and not post model
Re: Are 68/69 Roadrunner doors different? [Re: DAYCLONA] #2114732
07/21/16 12:57 PM
07/21/16 12:57 PM
Newton, KS
70B5Cuda Offline OP
70B5Cuda  Offline OP
Newton, KS
The 68 glass has a narrower glass runner than the 69-79, also the rear stainless rear trim on the side glass is different in shape/profile, assuming we are talking hardtop and not post model [/quote]
I have a 1968 roadrunner post car (RM21). With this in mind, what should I buy? I assumed 68 doors were all the same...
Re: Are 68/69 Roadrunner doors different? [Re: DAYCLONA] #2114734
07/21/16 12:58 PM
07/21/16 12:58 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Just like an A-Body the door shell is usable but everything inside needs to be transferred over as well as the lock hole position changed. It is MUCH easier to find a door from the same year and bolt it on. twocents
JB Rhinehart, Realist
A-Body's RULE!
