Are 68/69 Roadrunner doors different?
#2114117
07/20/16 03:45 PM
07/20/16 03:45 PM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
I need to replace a passenger side door on my 68 Roadrunner. I found a nice 69 door locally but I need to know if there are any differences. Thanks!!
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
Re: Are 68/69 Roadrunner doors different?
[Re: 70B5Cuda]
#2114216
07/20/16 05:17 PM
07/20/16 05:17 PM
Posts: 1,032 Ohio
dobie
Ohio
Yup. Door lock knobs are in different spots.
1968 Plymouth Road Runner
383 4 speed
[Re: DAYCLONA]
#2114645
07/21/16 11:19 AM
07/21/16 11:19 AM
70B5Cuda
Newton, KS
Along with the lock button location, which you can relocate if need be, having upper pads means no welding/body work if equipped?, you'll need to change out the glass and the rear glass tracks as they are different Could you explain this? I'm not sure I understand.
[Re: 70B5Cuda]
#2114664
07/21/16 11:41 AM
07/21/16 11:41 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Along with the lock button location, which you can relocate if need be, having upper pads means no welding/body work if equipped?, you'll need to change out the glass and the rear glass tracks as they are different Could you explain this? I'm not sure I understand. You'll need to drill a new hole for the rod lock knob to protruded thru the upper sill on the door, as the 68 is located in the rear, and 69-70 is more forward, if you have upper upholstered door pads there's no need to weld up the unused hole, other wise if your car has no pads, you'll need to weld/body work the upper inner portion of the door panel The 68 glass has a narrower glass runner than the 69-79, also the rear stainless rear trim on the side glass is different in shape/profile, assuming we are talking hardtop and not post model
[Re: DAYCLONA]
#2114732
07/21/16 12:57 PM
07/21/16 12:57 PM
70B5Cuda
Newton, KS
The 68 glass has a narrower glass runner than the 69-79, also the rear stainless rear trim on the side glass is different in shape/profile, assuming we are talking hardtop and not post model [/quote]
I have a 1968 roadrunner post car (RM21). With this in mind, what should I buy? I assumed 68 doors were all the same...
