Need Help Finding Cable For Kickdown LInkage #211447
02/01/09 10:55 PM
02/01/09 10:55 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I was removing my carb and since it was cold in the garage, the plastic end of the kickdown cable cracked. I looked and for a new cable it costs $100, which I think is crazy. Does anybody know of a different source for this, I am assuming there is none.
http://www.bouchillonperformance.com/BPEtkdc.asp
Re: Need Help Finding Cable For Kickdown LInkage [Re: bordin34] #211448
02/01/09 10:57 PM
02/01/09 10:57 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Why not call them tomorrow and see if they will sell you just the end, and mention why ?
Re: Need Help Finding Cable For Kickdown LInkage [Re: OzHemi] #211449
02/01/09 10:59 PM
02/01/09 10:59 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I looked at the end and it looks like it is kind of molded over the cable and wouldn't be possible to just replace the end. I will call them however.
Re: Need Help Finding Cable For Kickdown LInkage [Re: bordin34] #211450
02/01/09 11:01 PM
02/01/09 11:01 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Gotcha...thought it might have been a loose one that you could slide off easy
Re: Need Help Finding Cable For Kickdown LInkage [Re: OzHemi] #211451
02/01/09 11:02 PM
02/01/09 11:02 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
You can slide it down just not off.
Re: Need Help Finding Cable For Kickdown LInkage [Re: bordin34] #211452
02/01/09 11:12 PM
02/01/09 11:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Why cut you cut the tipof the cable off and then when you get the new piece use a brass barrel with a screw in it to keep it from coming back off. There should be enough cable to make up for the bit you cut off.
Re: Need Help Finding Cable For Kickdown LInkage [Re: stumpy] #211453
02/02/09 08:07 AM
02/02/09 08:07 AM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
Maybe, but what I am thinking now is to drill a hole in the plastic end since just the connector on the side broke off and put a bolt through the hole and attach it to the carb. Should work and cost $0.50
Re: Need Help Finding Cable For Kickdown LInkage [Re: bordin34] #211454
02/02/09 05:10 PM
02/02/09 05:10 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check with a motorcycle or snowmobile repair shop, there are several different type cable end repair fittings, the one below is an example:
http://cgi.ebay.com/ebaymotors/Parts-Acc...p4506.m20.l1116
Re: Need Help Finding Cable For Kickdown LInkage [Re: John_Kunkel] #211455
02/03/09 09:05 AM
02/03/09 09:05 AM
scratchnfotraction Offline
go to a jy and get the cable off a mag engine vehical
I think a bosh will use a stock mopar cable IIRC
