lead substitute??? #211419
02/01/09 10:14 PM
02/01/09 10:14 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
As some of you may remember, I had fuel pump trouble with my '67 Fury hardtop with the 318 engine back in December. I replaced the pump with a new one and it has been fine. The pump that was on the car looked fairly new but it was on the car when I bought it a year ago so I do not know how old it really was. I was using the CD-2 lead subtitute as directed in the fuel tank for valve seat protection because it is the original engine. Could that have messed up the pump and caused it to fail? Thanks for any info.
John
Re: lead substitute??? [Re: plymguy] #211420
02/01/09 10:16 PM
02/01/09 10:16 PM
Kentucky
dfsmopars Offline
dfsmopars  Offline
Kentucky
I have run lead additive quite a bit without problems.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: lead substitute??? [Re: plymguy] #211421
02/02/09 12:14 AM
02/02/09 12:14 AM
Spring Valley ,Ca.
moparsquid Offline
moparsquid  Offline
Spring Valley ,Ca.
more than likely it was the gas that ate the rubber diaphram in the pump. ca had all kinds of problems with the reformulated gas they had a few years ago.
Re: lead substitute??? [Re: moparsquid] #211422
02/02/09 02:54 PM
02/02/09 02:54 PM
Indiana
Cuda_Mike Offline
Cuda_Mike  Offline
Indiana
I've been using CD-2 in 2 different cars for 15 years with no fuel pump failures.
Re: lead substitute??? [Re: Cuda_Mike] #211423
02/07/09 05:12 PM
02/07/09 05:12 PM
Groton, MA.
BHuey Offline
BHuey  Offline
Groton, MA.
Where can I get CD-2 or any other lead substitute, I'm having a tough time finding it ?
Any chain stores like NAPA or Pet Boys carry it ?
70 Challenger R/T Conv. 66 Vette 427 Coupe 61 Vette FI Roadster
Re: lead substitute??? [Re: BHuey] #211424
02/07/09 05:38 PM
02/07/09 05:38 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
around here Walmart has it.
Re: lead substitute??? [Re: 05dakota] #211425
02/07/09 06:26 PM
02/07/09 06:26 PM
MA.
P
plymguy Offline OP
plymguy  Offline OP
P
MA.
Yes, That is where I get my CD-2. Wal-Mart.
John
Re: lead substitute??? [Re: plymguy] #211426
02/08/09 09:28 AM
02/08/09 09:28 AM
Groton, MA.
BHuey Offline
BHuey  Offline
Groton, MA.
OK thanks to all, I'll try the local Wal Mart
Re: lead substitute??? [Re: plymguy] #211427
02/10/09 02:37 PM
02/10/09 02:37 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Ethanol in gasoline will destroy old gaskets and seals. As far as a lead substitute, remember that one of the purposes of the lead was actuallu to lubricate the valves. I have used one ounce of type A ATF per ten gallons of unleaded fuel for many years in my old cars. I got the advice from a column that Don Garlits used to write in the Detroit News back in the 70's or 80's.
This is the land of the free because of the brave
