1970 B-body A-833 detailing
#2112311
07/18/16 10:24 AM
07/18/16 10:24 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang... I looked over at MMC, Roger Gibson and searched here and couldn't find any images on the detailing/markings on a A-833 18-spline 4-speed in my '70 Superbird. Unfortunately, my tranny was painted red by the original owner, so it is impossible to take reference pictures of this particular unit. I have a friend with a survivor 4speed Superbird, but there may be some markings on top I can't see...
Thanks in advance for any images...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 1970 B-body A-833 detailing
[Re: hemi68charger]
#2112346
07/18/16 11:34 AM
07/18/16 11:34 AM
Posts: 1,385 Az
69hemibeep
Az
If you have the broadcast sheet you would at least have the, I believe it is called the rack number. They were in different colors and numbers depending on plant. I always figured if you don't know don't do it someone might call you out on it.
1969 Hemi Roadrunner 2nd owner
[Re: 69hemibeep]
#2112350
07/18/16 11:41 AM
07/18/16 11:41 AM
hemi68charger
Houston, Tx
If you have the broadcast sheet you would at least have the, I believe it is called the rack number. They were in different colors and numbers depending on plant. I always figured if you don't know don't do it someone might call you out on it. Thanks.. Not worried about anyone calling me out on it... Never heard of the rack number.. Interesting.......
[Re: hemi68charger]
#2112369
07/18/16 12:29 PM
07/18/16 12:29 PM
Posts: 601 Mass
charge70
Mass
Those are the 3 large #'s that are stenciled on the passenger side of the case.They are the last 3 #'s of the actual part# for that 4 speed
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: charge70]
#2112399
07/18/16 01:14 PM
07/18/16 01:14 PM
hemi68charger
Houston, Tx
Those are the 3 large #'s that are stenciled on the passenger side of the case.They are the last 3 #'s of the actual part# for that 4 speed OK, that's what I thought they were, partial part number...
[Re: hemi68charger]
#2112454
07/18/16 02:07 PM
07/18/16 02:07 PM
Posts: 1,385 Az
69hemibeep
Az
Yes they are part #s. An old friend of mine that worked the assembly line said they sat in racks and pulled according to the build and the workers on his line reffered to that as a rack #
[Re: hemi68charger]
#2113124
07/19/16 11:23 AM
07/19/16 11:23 AM
Posts: 601 Mass
charge70
Mass
Troy,I have a build sheet for a 70 Charger R/T 440 4bbl 4 speed,and the code in the trans box on the sheet is 676.This may help.
[Re: charge70]
#2113170
07/19/16 11:54 AM
07/19/16 11:54 AM
hemi68charger
Houston, Tx
Troy,I have a build sheet for a 70 Charger R/T 440 4bbl 4 speed,and the code in the trans box on the sheet is 676.This may help. That helps, thanks..... But I was looking for images or either originals or restored OEM correct ones so I can see colors, font size, inspection markings, etc.......
[Re: hemi68charger]
#2113370
07/19/16 04:00 PM
07/19/16 04:00 PM
Posts: 1,385 Az
69hemibeep
Az
Mine is a 69 but I'm sure the # size is the same
