Stage 5 Hemi conversion heads? #2111179
07/16/16 03:16 PM
07/16/16 03:16 PM
Nebraska
70VcodeCoronetRT Offline OP
Nebraska
Just curious, is anyone running a set of these heads? Opinions? Looks like they take a lot of extra machine work. But I have a shot at a set pretty cheap. And thought this might be kind of cool to give a try?
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111217
07/16/16 05:11 PM
07/16/16 05:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Call The Shop stage 5 hemi conversion. Jerry Heard. 412-521-2367. He should b able to answer any question u have.
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111248
07/16/16 06:08 PM
07/16/16 06:08 PM
Victoria, B.C.
P
Pat Mac Offline
Pat Mac  Offline
P
Victoria, B.C.
Very high quality heads.Call Stage V and ask who is best at doing the block work.
Cheers,Pat
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111298
07/16/16 07:45 PM
07/16/16 07:45 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Lots of small issues. A big surprise is that the exhaust rocker ratio is short (about 1.4), so a custom cam should be considered to get a reasonable exhaust lift. Pushrod clearance is a pain, but that's not unusual for a HEMI.
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111519
07/17/16 02:06 AM
07/17/16 02:06 AM
You do know in the Hi Po race world of racing and street machines is that you usally get what you pay for, correct work
Do you want a cheap motor or do you want a good motor built with cheap parts shruggy work
I use to try to build good motors with cheap parts, it didn't work down realcrazy
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111520
07/17/16 02:11 AM
07/17/16 02:11 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
I have no personal experience with them, but I have heard that off-the-shelf hemi headers will not fit with the wedge motor mounts. So you need a motor plate or custom headers.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Stage 5 Hemi conversion heads? [Re: Hemi_Joel] #2111527
07/17/16 02:35 AM
07/17/16 02:35 AM
Victoria, B.C.
P
Pat Mac Offline
Pat Mac  Offline
P
Victoria, B.C.
Stage V's are not cheap..but as the saying goes "you get what you pay for" I believe one of the main header manufacturers is making headers for the raised port Stage V's
One needs to keep in mind that when these heads were made original Hemi blocks were big money and hard to find. 440 blocks were cheap and plentiful.
The 440 block treatment consists of drilling and tapping for larger bolts/studs on the main and some on the deck.Clearance for pushrods and drilling out the pickup and some of the oil galleries.
Cheers,Pat
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111583
07/17/16 08:16 AM
07/17/16 08:16 AM
Nebraska
Nebraska
OK, thanks guys. not for me then.
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111600
07/17/16 09:28 AM
07/17/16 09:28 AM
Parts unknown
590 Challenger Offline
Parts unknown
I run the regular stage V heads, they make some great stuff. Motor plate and extra machine work would well be worth it. The exhaust ports are raised really helping the flow. TTI makes the headers, I run them on mine (until I make some zoomies) You will save lots of money for he machine work with being able to use a 440 block
Re: Stage 5 Hemi conversion heads? [Re: 590 Challenger] #2111619
07/17/16 10:15 AM
07/17/16 10:15 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
but the flip side is he will have a basterd oddball two bolt main motor that will never be worth much. JMO.
Re: Stage 5 Hemi conversion heads? [Re: Hot 340] #2111629
07/17/16 10:32 AM
07/17/16 10:32 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
My engine builder has built them before...He can do the machine work, not sure the cost though...They make nice street engines if your not trying to rotate the earth.
Re: Stage 5 Hemi conversion heads? [Re: Hot 340] #2111655
07/17/16 11:18 AM
07/17/16 11:18 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Exactly. Those 440 block Hemi heads are around only because some people want the Hemi look without having to pay the Hemi price (not implying that OP is one of those people).
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2111704
07/17/16 12:37 PM
07/17/16 12:37 PM
Parts unknown
Parts unknown
Good points, the heads are good and capable of making more power than the blocks can handle unless you have an after market block kicking around the garage and want a Hemi. It would make a very cool street car motor
Re: Stage 5 Hemi conversion heads? [Re: jughed] #2111792
07/17/16 02:41 PM
07/17/16 02:41 PM
Dragula Offline
Dragula  Offline
That is why they make girdles....
Re: Stage 5 Hemi conversion heads? [Re: Dragula] #2112007
07/17/16 07:53 PM
07/17/16 07:53 PM
The girdles do not increase the strength or thickness of the main webbing in any block work Know your parts limits and then choose them wisely uptwocents
How many racers and engine builders on here have put girdles on RB blocks and had them come back later with cracks in the main webbing running up into the cylinders work I've seen and heard of more than two shruggy
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2112086
07/17/16 10:25 PM
07/17/16 10:25 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
When I was building engines I put girdles on any 700+ HP wedge using a stock block. Of course if we were shooting for that HP level I also filled the block. Never had one fail, yet I saw several similar engines without girdles that cracked. I think girdles help but sanity and reasonable expectations should prevail.
One other note: Girdle installation can cause other problems if the shims are not measured and set correctly.
Re: Stage 5 Hemi conversion heads? [Re: Cab_Burge] #2112157
07/18/16 12:33 AM
07/18/16 12:33 AM
Dragula Offline
Dragula  Offline
I am over 700hp on my stroked 440 and six seasons/years on it. No cracks yet. Lots of passes on it. We have a number of stroked wedges running on the street and strip, and the girdle is the only way to go for anything over 600hp that is going to be flogged on a drag strip. Keeps cap walk away and allows it to live.
If its a cushy street car making 700hp, I would still put one on, but some folks don't want them.
Here is my 6.19 pass from this weekend on my pump gas stroked 440!
https://www.youtube.com/watch?v=Z_XTmRBuvWs
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2112259
07/18/16 04:21 AM
07/18/16 04:21 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
NOTHING completely STOPS the caps from bouncing on an RB Mopar.......Nothing. With the design of the block and clamping arrangement it CAN'T be stopped. All you can do is make the parts beefier to withstand it. Another thing you can't do in a stock block. Can't add material where it isn't
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2112426
07/18/16 01:40 PM
07/18/16 01:40 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I think Steve Magnante ran the conversion heads on his Dart. Read the article in an old Mopar Action Tech Edition.
Re: Stage 5 Hemi conversion heads? [Re: 70VcodeCoronetRT] #2112469
07/18/16 02:35 PM
07/18/16 02:35 PM
Niles , Ohio
therocks Online content
therocks  Online Content
Niles , Ohio
Wonder if someone watched the Jokers from here.Fat and Furious supposedly paid 25K for one of the built motors.If I was paying for a hemi in my car and for what they supposedly got paid it better be a Hemi.For less than that you could have got a real Hemi.Rocky
Chrysler Firepower
