torqueflite problems #2110348
07/15/16 02:05 AM
07/15/16 02:05 AM
ky, usa
littlejohn44 Offline OP
ky, usa
Not sure what happened , I missed a shift went 1-3 and now when I shift into second it goes no where. It acts like it is trying to go but something is holding it . if I rev it in second it tries to pull hard but as soon as i let off it acts like i put the brakes on hard. The fluid smells burnt and it did get pretty hot. Anyone with any clues? I have 10 passes on it since the rebuild.
Re: torqueflite problems [Re: littlejohn44] #2110350
07/15/16 02:16 AM
07/15/16 02:16 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The servo is cocked and wont release the band..
you will be pulling the trans is cooked
wave
Re: torqueflite problems [Re: littlejohn44] #2110504
07/15/16 01:46 PM
07/15/16 01:46 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
What he said. Burnt fluid? Get it out and get it apart. Not sure why 1-3 shift would cause something to come apart or how the front piston could cock unless it broke. Maybe welded high gear clutch pack or broke something in that drum. Regardless, we can speculate, but it needs to go on the bench, get cleaned up and fix what's busted.
Re: torqueflite problems [Re: littlejohn44] #2110513
07/15/16 02:10 PM
07/15/16 02:10 PM
ky, usa
ky, usa
Its coming out just kinda wanted a heads up, not sure how one works so that gives me some info to check out.
Re: torqueflite problems [Re: littlejohn44] #2110524
07/15/16 02:24 PM
07/15/16 02:24 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
They are pretty simple. Burnt fluid = black and blue parts, frictions ruined. Pictures of anything questionable help.
Re: torqueflite problems [Re: littlejohn44] #2110562
07/15/16 03:37 PM
07/15/16 03:37 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Where in KY are you?
They are not hard to replace parts in. If your around louisville you can get parts at W.I.T. (Whatever It Takes). They are in Brooks. 1-800-940-0197. They even have a book for $35.00 that is step by step instructions.
Re: torqueflite problems [Re: littlejohn44] #2110581
07/15/16 04:11 PM
07/15/16 04:11 PM
ky, usa
ky, usa
I'm in paducah area . If I am going to have to rebuild again Im looking in to the billet stuff that Andy on here sales. What clutches and steels do y'all run in yours.
Re: torqueflite problems [Re: littlejohn44] #2110592
07/15/16 04:24 PM
07/15/16 04:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I think the clutches are blue
Re: torqueflite problems [Re: littlejohn44] #2110595
07/15/16 04:32 PM
07/15/16 04:32 PM
ky, usa
ky, usa
The ones that i had put in at the rebuild were tci brand, not sure who makes them. I am hoping thats all that is fried
Re: torqueflite problems [Re: littlejohn44] #2110713
07/15/16 07:30 PM
07/15/16 07:30 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Are you still using the kick down crap?
Re: torqueflite problems [Re: littlejohn44] #2110811
07/15/16 09:39 PM
07/15/16 09:39 PM
ky, usa
ky, usa
its a manual shift vb
