Re: Who sells the grooved copper crush washers?
[Re: stumpy]
#2110172
07/14/16 10:38 PM
07/14/16 10:38 PM
RapidRobert
None seal as well as the originals. I always reuse them. This, the new dealer ones are smooth. gently wire brush the originals and use a scribe to clean the circular grooves & an option is a very light coat of sealant (I used "the right stuff" on a toughie), no leaks
[Re: fatsat]
#2110289
07/15/16 12:43 AM
07/15/16 12:43 AM
Posts: 4,730 Florida
BDW
[Re: Big_E]
#2110361
07/15/16 03:26 AM
07/15/16 03:26 AM
Posts: 270 Missouri
Big_E
Missouri
[Re: fatsat]
#2110385
07/15/16 08:41 AM
07/15/16 08:41 AM
BDW
[Re: fatsat]
#2110452
07/15/16 12:02 PM
07/15/16 12:02 PM
Posts: 21,073 Niles , Ohio
therocks
Niles , Ohio
If not damaged I also use the old ones.Have done it at the shop and home for over 30 years.Had too many new ones leak.Rocky
Chrysler Firepower
[Re: fatsat]
#2110482
07/15/16 01:05 PM
07/15/16 01:05 PM
Posts: 3,281 West Coast, USA
jbc426
West Coast, USA
I used to have problems with them until I started to tighten and loosen them half a dozen times. This allows them to seat much better.
I do the same thing with new rocker arms and adjuster jam nuts.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
