1979 Jeep Cherokee Quadratrack jerks #2106986
07/09/16 09:26 PM
07/09/16 09:26 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Jerks when turning, I just replaced both axle Ujoints
It is full time 4wdrive Quad track
it still jerks about the same as before, What's happening.
Thanks!
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2107007
07/09/16 10:05 PM
07/09/16 10:05 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Varnished clutches in the transfer case. Typical fix is to do tight figure eight in a parking lot for a while and change the oil.
Get the correct oil from BJ's off road.
Angry white pureblood male
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2107012
07/09/16 10:20 PM
07/09/16 10:20 PM
places
79powerwagon Offline
places
My 79 PW did that also. I never did anything to check to see if it was a problem or not (at the time, everyone simply said that's just how it is). After more than a decade of daily driving, nothing bad ever happened to it.
Doing what Mr. Runner is advising sounds like good advice. smile
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2107045
07/09/16 11:29 PM
07/09/16 11:29 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks for jarring my memory about the turning thing.
I'll try that and see what happens.
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2107370
07/10/16 04:15 PM
07/10/16 04:15 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Jeep quadratrac cases have a small limited slip differential in the case. The np203 doesn't.
The limited slip clutch is known to varnish up and cause the jerkyness. The figure eight thing helps break up the varnish on the clutches.
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2107864
07/11/16 01:25 PM
07/11/16 01:25 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
Thanks again ruderunner
Re: 1979 Jeep Cherokee Quadratrack jerks [Re: MO_PA] #2109042
07/12/16 10:53 PM
07/12/16 10:53 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
De Nada. Own both transfer cases, have owned several of the q tracs over the years. It pretty normal but lots of people think it means rebuild time.
Np203 behind automatic transmission are usually smooth, but behind a stick they also get jerky. Just the nature of the beast.
