Need a measurement - Dodge Air Grabber #210879
02/01/09 04:59 PM
02/01/09 04:59 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I have the small outboard air grabber box to hood seal dimensions and I have the strips of material cut for the large, center section air grabber box to hood seal. But I need to know the outer perimeter length of the large seal.
From the factory it's just a long strip that's butt spliced (on a 45 dregee angle) to form a large circular shape. I used to know the dimension. From memory I thought it was 54" I know it's not terribly critical. +/- .25-.5" is probably fine.
Anyone have box handy the can use a seamstress tape or piece of string (something very flexible and accurate) to measure the perimiter of a seal on a box. Would obviously have to be a box thats not mounted.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210880
02/01/09 05:23 PM
02/01/09 05:23 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Not exactly sure what you are looking for, but I can make some measurements if you want. Are you looking for the outside dia of the airgrabber box where it mounts to the underside of the hood? The one with all the studs? Let me know. I'm in the same boat...what are you using as a gasket? I can measure at the box or at the underside of the hood...let me know.
71 440-6 4spd & 69 Hemi 4spd
Re: Need a measurement - Dodge Air Grabber [Re: hemi_doug] #210881
02/01/09 05:31 PM
02/01/09 05:31 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Oops. Shoulda said 69 (70?).
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210882
02/01/09 05:36 PM
02/01/09 05:36 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Well that makes a difference...the 71 is 58 1/2 inches....I just measured it (lol)...So what are you using for material?
Re: Need a measurement - Dodge Air Grabber [Re: hemi_doug] #210883
02/01/09 05:39 PM
02/01/09 05:39 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Need this one. I have the correct, low density epdm-neoprene foam cut into 1/2" x 1/2" x 60" strips. For the outer smaller openings I cut them to shape from 1/4" thick material.
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210884
02/01/09 05:40 PM
02/01/09 05:40 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Again a nice guy, Dave Chapell, scraped one of these off and sent it to me to duplicate. So I'm all set with these.
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210885
02/01/09 05:42 PM
02/01/09 05:42 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I have the 71-72 Dodge door to hood gasket. It's the same as the 70 Road Runner. Also have the large square 70 RR box to hood gasket. Not sure if that too is the same for 71-72 Dodge. You know?
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210886
02/01/09 06:18 PM
02/01/09 06:18 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
I don't know for sure, but I have seen them off a hood and they looked the same...
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210887
02/02/09 02:31 AM
02/02/09 02:31 AM
Shoreline, Washington
72roadrunnergtx Offline
The under hood air grabber parts for the 70’ Plymouth b-body/71-72’ Dodge b-body are interchangeable the 71-72’ Plymouths. The air box uses the same gasket to seal to the hood or bubble.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Need a measurement - Dodge Air Grabber [Re: 72roadrunnergtx] #210888
02/02/09 09:19 AM
02/02/09 09:19 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks for the info!
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210889
02/08/09 03:54 PM
02/08/09 03:54 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
BTTT
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210890
03/05/09 09:57 PM
03/05/09 09:57 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
One more time?
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210891
03/08/09 05:05 PM
03/08/09 05:05 PM
lancaster, new york
macmic87 Offline
macmic87  Offline
lancaster, new york
measured around the outside of an original gasket and it was exactly 56". this is for the center section out of a 69 ramcharger.
Re: Need a measurement - Dodge Air Grabber [Re: macmic87] #210892
03/08/09 05:41 PM
03/08/09 05:41 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Finally! Thanks!
Re: Need a measurement - Dodge Air Grabber [Re: 71TA] #210893
03/14/09 02:44 PM
03/14/09 02:44 PM
Canada
DmanSRT71 Offline
DmanSRT71  Offline
Canada
Just saw this post, and I got to thinking - is Fram the only manufacturer of the Air Grabber air cleaner?
Does anyone know where is the best price for an air grabber air cleaner? Summit lists for $80.
Darren
69 Road Runner 383/auto/N96 71 Demon 340/4 spd Would like to find a rust free Cuda body.
