Re: Engine balancing with tungsten weights
[Re: Mopar Sam]
#2107945
07/11/16 03:28 PM
07/11/16 03:28 PM
Posts: 25,791 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Mallory Metal is a brand name for an alloy of tungsten with other metallic elements added to improve machining.
[Re: Moparnut426]
#2108474
07/12/16 02:14 AM
07/12/16 02:14 AM
Posts: 4,206 New York
polyspheric
New York
You can use anything with a higher specific gravity than steel. How much you use depends on how much steel you remove, the math is accurate. You just substitute the SG of your insert material when you calculate to see how big the holes are. Gold is excellent but... Lead works just fine and costs almost nothing, you just need more of it.
Boffin Emeritus
