Buying this 1970 wrecked truck, what years interchange? #2104071
07/05/16 03:19 AM
07/05/16 03:19 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Im buying this 3/4 ton long bed sweptline. Its a running driving truck but was hit on the side Im buying it to turn into a short bed in time to be a hotrod type that will go with my W200 POWER WAGON SHORT BED. I need a door and THINK (?) that the door I need will be a 68-71> Am I correct?
Im also looking for a thread on how best to turn this into a short bed?
Thanks for any info.
RUMBLON
Re: Buying this 1970 wrecked truck, what years interchange? [Re: RUMBLON] #2104073
07/05/16 03:23 AM
07/05/16 03:23 AM
Midland,Tx
wyldebill Offline
wyldebill  Offline
Midland,Tx
Any push button door handle door, should work. But all 61-71 will bolt on, I believe
Re: Buying this 1970 wrecked truck, what years interchange? [Re: wyldebill] #2104075
07/05/16 03:34 AM
07/05/16 03:34 AM
Cambridge Idaho
RUMBLON Offline OP
RUMBLON  Offline OP
Cambridge Idaho
Thats what I thought when I built my 67 Power wagon and swapped out the front clip and short bed with a 63. The doors were different on the jam area where they close.
Im sure the front clips are find but the doors I think only fit particular years.
RUMBLON
Re: Buying this 1970 wrecked truck, what years interchange? [Re: RUMBLON] #2104137
07/05/16 11:09 AM
07/05/16 11:09 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
68-71 is safe Door wise
Re: Buying this 1970 wrecked truck, what years interchange? [Re: RUMBLON] #2105377
07/07/16 01:01 AM
07/07/16 01:01 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you want to make it a short box truck, I believe you will want to locate a good short box first, they are pretty hard to find.
Then you need a short box frame, either another 64-71 frame, or a short box 72-93 frame (slight modification to the frame above the rear axle), or you need to remove a section from in front of the rear leaf springs and a section behind the rear leaf springs from your existing frame, or you need to splice in the rear 1/2 of a short box frame to the front of your existing frame. Gene
Re: Buying this 1970 wrecked truck, what years interchange? [Re: poorboy] #2105380
07/07/16 01:04 AM
07/07/16 01:04 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
The doors will bolt on from 61-66 but latches will be different, use a 67-71 door it will be much easier. Check out sweptline.org for more info on hacking it into a shortbed. wave
JB Rhinehart, Realist
A-Body's RULE!
Re: Buying this 1970 wrecked truck, what years interchange? [Re: Rhinodart] #2106120
07/08/16 09:38 AM
07/08/16 09:38 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
I posted a picture of a truck that was cut into a short from facebook
Re: Buying this 1970 wrecked truck, what years interchange? [Re: RUMBLON] #2106629
07/09/16 12:58 AM
07/09/16 12:58 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
I like the Sweptlines in the long bed better.The lines on the body seem to flow better.
Re: Buying this 1970 wrecked truck, what years interchange? [Re: RTSrunner] #2107397
07/10/16 05:30 PM
07/10/16 05:30 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
You got that right... punkrocka
A-Body's RULE!
Re: Buying this 1970 wrecked truck, what years interchange? [Re: Rhinodart] #2107481
07/10/16 08:09 PM
07/10/16 08:09 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Looks like a good score. I have a complete short box, sweptline parts truck here at the house with everything you need. It's a 61 frame with a 67 "custom" trim cab.
Shoot me a PM if you come across anything you can't find locally.
Re: Buying this 1970 wrecked truck, what years interchange? [Re: Jeremiah] #2109747
07/14/16 01:24 AM
07/14/16 01:24 AM
ohio
bbtrux Offline
bbtrux  Offline
ohio
The latches were different pre 68 also.Dont bolt into the door the same.
Re: Buying this 1970 wrecked truck, what years interchange? [Re: bbtrux] #2109842
07/14/16 11:31 AM
07/14/16 11:31 AM
Des Moines IA
Soopernaut Online content
Soopernaut  Online Content
Des Moines IA
Pre 67.
1970 Dodge d100/eventually going on a 77 D100 frame
