Experience with Innovate LM-2??? #2093829
06/18/16 04:11 AM
06/18/16 04:11 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
I've been thinking about picking up a wideband AFR meter and have been looking at the Innovate LM-2. I've run several searches here on Moparts and it seems like a fair number of people here have had good experiences with them; however, other reviews on the web are all over the place, with lots of people really hating this particular model.
You can currently buy an LM-2 for $240 on Amazon, which is about $100 off retail, and I like the fact that the LM-2 can data log and that you can simultaneously log RPM with a $30 inductive clamp add on. Seems like a pretty good deal, as long as the thing works.
Looking to get some fresh opinions from folks that have some experience with these things. Do you love yours or hate it?
Thanks up
Re: Experience with Innovate LM-2??? [Re: rss] #2093873
06/18/16 11:06 AM
06/18/16 11:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
They did have problems when the LM-2 came out.. I
assume those problems have been resolved... I run
a LM-1 and use a camera as a data logger... just make
sure that the tach and the A/F meter are in the same frame
and the sound works to see if you are starting to load differently
along with the tach
wave
Re: Experience with Innovate LM-2??? [Re: rss] #2093877
06/18/16 11:10 AM
06/18/16 11:10 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
No experience yet, but i have one arriving in a couples days.
That $240 on Ebay is for the basic kit, the complete kits are $309
72 Plymouth Roadrunner 11.08@123.25
Re: Experience with Innovate LM-2??? [Re: Roughbird72] #2093929
06/18/16 01:53 PM
06/18/16 01:53 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good price and I too run the 1 but need a go-pro to monitor the gauges.......
Re: Experience with Innovate LM-2??? [Re: Thumperdart] #2093972
06/18/16 03:07 PM
06/18/16 03:07 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
If you are running a MSD ignition then don't waste your money on the inductive clamp attachment it don't work with the multiple spark, I had to hard wire mine into the tach out put with the analog cable and just leave it in the car,, now if you are going to use it on multiple vehicles with factory ignition you will be fine with it, I love mine
Re: Experience with Innovate LM-2??? [Re: rss] #2094344
06/19/16 11:23 AM
06/19/16 11:23 AM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I run the LM-1, LMA-2 RPM Converter and LM-3 Auxbox (this last one allows you to capture a whole wack of sensor inputs).
The LM1-1/LMA-2 combo has been trouble free. The LM-1/LM-3 however I have not been able to successfully connect. The LM-3 refuses to read out the tach signal. I even sent it in for service, the process was rather poor...very little info being reported out, etc, etc...it took a number of email exchanges to be finally told that the box checked out fine and that maybe there is signal noise and I should make up a little circuit to fine tune with.
Hmm...OK, no big deal, I am handy with electronic components and can solder a few things together...but the company, from a service/customer interface point of view simply dissapointed.
EDIT: Oh, keep in mind that neither LM-1 or LM-3 will allow you to capture multiple O2 sensor signals, for that you really need to move to the newer LM-2 or LC-2 controllers. Even then they sell two versions (of each I think), one is a single O2 setup then the second one is a two O2 setup...so yeah, the same box, but if you want two O2 sensor reading you'll have to cough up the hard cash...and we're not talking just an extra $25 here either...
Re: Experience with Innovate LM-2??? [Re: Diplomat360] #2094371
06/19/16 12:21 PM
06/19/16 12:21 PM
NY
challenger451ci Offline
NY
I use an LM-2 to log A/F, Pan Vac, nitrous fuel pressure, and nitrous bottle pressure. Certainly not as easy and clean as a Racepak, but it gets the job done for about $800.00 total investment including the sensors. I use a company called Transducers Direct for the sensors. They're ~$100.00 each. Pick the range you want to measure and the 0-5VDC output. Wire them into the Analog channels to the LM using shielded cable and keep them away from noise(ignition etc..). I landed all the Analog 0VDC reference signals and the shields to the same terminal block to keep noise to a minimum. Seems to work decent on my hoagie.
I'm thinking about getting the LMA-3 so I can log DS speed, shock travel and have a G-meter.
Re: Experience with Innovate LM-2??? [Re: rss] #2095442
06/21/16 02:58 AM
06/21/16 02:58 AM
Seattle, WA
3
375inStroke Offline
Special needs person
375inStroke  Offline
3
Seattle, WA
I have one on our endurance racer. We don't datalog, just read the ratio. The narrowband output works fine for the stock engine ECU. No problems.
Re: Experience with Innovate LM-2??? [Re: 375inStroke] #2097128
06/24/16 01:37 AM
06/24/16 01:37 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Thanks for all the replies guys. I think I'll pull the trigger and give it a shot.
Re: Experience with Innovate LM-2??? [Re: rss] #2097363
06/24/16 02:23 PM
06/24/16 02:23 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have the LM-2 with a single sensor, IMO it's a must for carb tuning. When working on cruise afr's you can make changes and log after each change and see the effects.
Re: Experience with Innovate LM-2??? [Re: justinp61] #2107319
07/10/16 02:49 PM
07/10/16 02:49 PM
Roughbird72 Offline
Roughbird72  Offline
iagree
I've been using mine for a couple weeks now.
Wow! was i way over jetted eek
Re: Experience with Innovate LM-2??? [Re: Roughbird72] #2107325
07/10/16 02:56 PM
07/10/16 02:56 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
iagree
Many are......
Re: Experience with Innovate LM-2??? [Re: Thumperdart] #2107327
07/10/16 03:01 PM
07/10/16 03:01 PM
Roughbird72 Offline
Roughbird72  Offline
iagree
Many are......
Mid 12s cruising at highway speed & mid 10s at wot is just A BIT rich. lol
I wish i would have bought one years ago.
Re: Experience with Innovate LM-2??? [Re: Roughbird72] #2107336
07/10/16 03:15 PM
07/10/16 03:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The day I dropped my roller motor in the car it was a 9 second car w/a 10 second tune THEN the w/b gave me directions to tune and bam, 9.98 off the trailer and now w/more tuning 9.79 4 years ago and hopefully a 9.59-9.62 coming soon...........
Re: Experience with Innovate LM-2??? [Re: Thumperdart] #2107347
07/10/16 03:28 PM
07/10/16 03:28 PM
Roughbird72 Offline
Roughbird72  Offline
