Bonding door mirror glass on E-Body?? #210693
02/01/09 03:45 PM
02/01/09 03:45 PM
London, England
Gavin Offline OP
Gavin  Offline OP
London, England
Is regular RTV silicone OK to bond the mirror glass to the metal baseplate? It looks like what the factory used. Or is there some other stuff to use, like the stuff they bond windshields with?
I have the RTV...don't have the other stuff
Re: Bonding door mirror glass on E-Body?? [Re: Gavin] #210694
02/01/09 04:05 PM
02/01/09 04:05 PM
Modesto CA
BFASTER Offline
BFASTER  Offline
Modesto CA
I've used the regular black gasket sealer on side mirrors and never had one fall out. Make sure both surfaces are extremely clean bfore laying down a bead!
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Bonding door mirror glass on E-Body?? [Re: BFASTER] #210695
02/01/09 06:09 PM
02/01/09 06:09 PM
London, England
Gavin Offline OP
Gavin  Offline OP
London, England
RTV it is!
Re: Bonding door mirror glass on E-Body?? [Re: Gavin] #210696
02/01/09 07:11 PM
02/01/09 07:11 PM
Maple Ridge, BC, Canada
Barnabas_Kriss Offline
I used a black urethane windshield adehesive. Worked very well.
Re: Bonding door mirror glass on E-Body?? [Re: Gavin] #210697
02/02/09 09:25 AM
02/02/09 09:25 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
RTV it is!
i am assuming RTV means silicone sealer. DO NOT USE silicone sealer. it will not work.
try windshield urethane or some type of epoxy, like JB weld.
perception is 90% of reality
Re: Bonding door mirror glass on E-Body?? [Re: Mr T2U] #210698
02/02/09 01:49 PM
02/02/09 01:49 PM
London, England
Gavin Offline OP
Gavin  Offline OP
London, England
RTV it is!
Yes, I'm talking about silicone gasket maker/sealer etc. Why do you think it shouldn't be used? (BFASTER has used it and it worked fine).
I could see the windshield adhesive would be good, but if silicone does it then I have that to hand. JB Weld wouldn't work as it would be a nightmare to replace the glass if you ever needed to. The factory did use a flexible material...
Re: Bonding door mirror glass on E-Body?? [Re: Gavin] #210699
02/02/09 02:54 PM
02/02/09 02:54 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Take the mirror to your local windshield installer & see if he will put four little blobs of urethane on the pads, drop the mirror in place & tape it...
