Jesel adjusters for pushrod oiling vs spray bars? #2106648
07/09/16 01:35 AM
07/09/16 01:35 AM
Bellevue, NE
Charger453 Offline OP
Bellevue, NE
I assume they have a different adjuster for each application? I'm trying to get set up for pushrod oiling, but the adjuster is hollow. I've been playing around with restricting a set of Comp 892 lifters. It was built with the lifters having a .062" hole and that was enough for oil to spray the inner fenders like a hose. I'm down to a .020" hole and it still has too much oil coming thru the adjuster. Not a graden hose spray anymore, but a small,steady stream that still pools up in the cylinder head.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106653
07/09/16 01:43 AM
07/09/16 01:43 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I would like to know how your closing off the hole
wave
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106656
07/09/16 01:50 AM
07/09/16 01:50 AM
Bellevue, NE
Bellevue, NE
Jbweld for now until I know what size it wants. I don't know that I trust expoxy in the engine even though that's Comp's recommendation. Once I know how much to restrict them, I was considering trying to press in a brass plug and drilling that.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106658
07/09/16 01:53 AM
07/09/16 01:53 AM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
You need to put a restrictor in your push rod We ran a .020 in our B-1 with Jesel Rockers
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106659
07/09/16 01:53 AM
07/09/16 01:53 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Afaik, Jesel doesn't make any specific adjuster for spray bar oiling.
They pretty much assume the rockers will be pushrod oiled.
A .020 hole for each lifter/rocker would certainly be plenty of oil, especially when you consider how little oil can squeeze through the area of a proper edge orifice oiling set up.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106670
07/09/16 02:22 AM
07/09/16 02:22 AM
Bellevue, NE
Bellevue, NE
Thanks for the input guys. I tried calling Jesel last Friday to ask, but they were closed for the weekend and it kept slipping my mind this week. Perhaps pushrod restrictors is my next approach.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106676
07/09/16 02:36 AM
07/09/16 02:36 AM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
every motor I build gets a .030" restrictor in the pushrod, would get solid adjusters and be done with it..
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106745
07/09/16 11:18 AM
07/09/16 11:18 AM
On the paired shaft Jesel non alumimun rockers I have the adjusters are hollow also and there is no provisions to oil the shafts or valve tips other than splash oiling work I think my Manton pushrods have a. 080 restrictor in them work I'll check as I haven't put oil in that motor or even primed it yet luck I am using the Comp AMC solid roller lifters in it with one oiling hole in the lifters plugged.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Cab_Burge] #2106759
07/09/16 11:45 AM
07/09/16 11:45 AM
Virginia
moparroad Offline
moparroad  Offline
Virginia
I agree that the oiling hole in the adjuster is to large. While priming with a drill I sent oil to a 10' ceiling. Ended up using solid adjusters, which still provides oil to the adjuster cup, and restricted spray bars. which oils the rest. Works well for me.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106893
07/09/16 05:04 PM
07/09/16 05:04 PM
Bellevue, NE
Bellevue, NE
From what I see Jesel is quite proud of their adjusters at nearly $300/set.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2106917
07/09/16 05:55 PM
07/09/16 05:55 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Not sure but maybe t&d adjusters will work. They offer both style adjuster but they are pricey as well at 14-16 dollars each.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: mopar dave] #2106922
07/09/16 06:05 PM
07/09/16 06:05 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I know someone that may sell a set. LOL
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: mopar dave] #2106992
07/09/16 09:35 PM
07/09/16 09:35 PM
All the good heat treated adjusters are around that price, depending on which brand and who you buy from shruggy The last set I bought for my Hughes cyro treated rockers where the same price,$13.50+ each plus shipping shruggy
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: pittsburghracer] #2107011
07/09/16 10:17 PM
07/09/16 10:17 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
LOL. For sure. You have an extra set.
Re: Jesel adjusters for pushrod oiling vs spray bars? [Re: Charger453] #2107029
07/09/16 10:47 PM
07/09/16 10:47 PM
Bellevue, NE
Bellevue, NE
I realize nothing is cheap anymore, but it caught me a little off guard. If anyone has some extras, I'm all ears if we determine they'll work.
