What is correct finish..'68 Super Bee hood inserts.. #210681
02/01/09 03:25 PM
02/01/09 03:25 PM
Mansfield,Ohio
moparrulzzz Offline OP
Mansfield,Ohio
The Bulge Hood inserts on my hood has been painted in the past. What was the finish it came from the factory with?
I need to do something with them.
I wonder if they would look good Gloss Black
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: moparrulzzz] #210682
02/01/09 03:35 PM
02/01/09 03:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
should be a satin black...
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: 1_WILD_RT] #210683
02/01/09 03:54 PM
02/01/09 03:54 PM
Mansfield,Ohio
Mansfield,Ohio
Really!! Mine are painted silver.
Did it matter what the color of the car was or were they all Satin Black?
I am going to have to clean mine up and try a Satin Black and see how it looks!
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: 1_WILD_RT] #210684
02/01/09 05:21 PM
02/01/09 05:21 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
with a satin chrome border and trim
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: gtx6970] #210685
02/01/09 05:45 PM
02/01/09 05:45 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: moparrulzzz] #210686
02/02/09 10:15 AM
02/02/09 10:15 AM
rochester michigan, oakland co...
drmonday Offline
drmonday  Offline
FYI. I rechromed the hood inserts on my R/T and used wide black tape striping instead of painting. Its tough to get paint to stick to chrome. Looks great.
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: drmonday] #210687
02/02/09 01:43 PM
02/02/09 01:43 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Thats great except they weren't originally shiney chrome...The metal wasn't polished before plating, it has a grainy/sandblasted appearamce which holds paint pretty well....
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: 1_WILD_RT] #210688
02/02/09 09:07 PM
02/02/09 09:07 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Ok while reading this I believe there were 2 different batches of these...I have 2 sets of these. One set which is original chrome and shiny,then another set that was the "dull" finish. I have also seen these around swap meets too like this. The ones that were shiny chrome are pitted the most,the ones that were dull survived much better.
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: 68CoronetRT] #210689
02/02/09 09:39 PM
02/02/09 09:39 PM
Mansfield,Ohio
Mansfield,Ohio
Jim what did you do to your inserts. Paint or did you have them rechromed??
Thats the look I was after. Mine are not in that good of shape but thought I could do a little careful grinding and a little all metal(or similar) to smooth them out where the pits were
Thnx Chuck
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: moparrulzzz] #210690
02/02/09 09:50 PM
02/02/09 09:50 PM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
First I buffed the chrome edges to a nice shine, then cleaned everything real good, taped them off and painted the centers with Satin Black.
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: 68CoronetRT] #210691
02/02/09 10:04 PM
02/02/09 10:04 PM
Mansfield,Ohio
Mansfield,Ohio
I don't think mine will buff. It looks like thet were spray painted.
I might try cleaning with paint thinner and see if it will come off, then try buffing.
Did you get that clip I sent you a few months back for your fender? I tried to email you and it kept coming back undeliverable. Hope it worked out ok!!
Chuck
Re: What is correct finish..'68 Super Bee hood inserts.. [Re: moparrulzzz] #210692
02/03/09 09:13 AM
02/03/09 09:13 AM
Arizona
68CoronetRT Offline
68CoronetRT  Offline
Arizona
. . . Did you get that clip I sent you a few months back for your fender? I tried to email you and it kept coming back undeliverable. Hope it worked out ok!! Chuck
Yes. I sent you an email as well thanking you. I changed my email address so it might have been during that time. The new address is in my profile/contact information. Thanks again!
