Dana 60 gear swap and sure grip rebuild #2106804
07/09/16 01:24 PM
07/09/16 01:24 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I'm looking for an online resource for info on steps to rebuild.
I'm swapping damaged 4.10 for another set.
All new bearings and replacing the clutches in the sure grip.
71 Barracuda 383 4spd (500ci)
69 camaro 598, NOS
69 barracuda bbc procharger
77 t/a 6.0 turbo project
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
78 Warlock 5.7 hemi project
Re: Dana 60 gear swap and sure grip rebuild [Re: EV2CUDA] #2106818
07/09/16 01:55 PM
07/09/16 01:55 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Re: Dana 60 gear swap and sure grip rebuild [Re: EV2CUDA] #2106828
07/09/16 02:16 PM
07/09/16 02:16 PM
Oh Canada
E
EV2CUDA Offline OP
EV2CUDA  Offline OP
E
Oh Canada
I bought my parts from dr Diff. 👍
69 camaro 598, NOS
78 t/a 400
77 corvette
1983 hurst/olds
03 Viper
79 360 macho
71 demon 360
Re: Dana 60 gear swap and sure grip rebuild [Re: EV2CUDA] #2107106
07/10/16 01:16 AM
07/10/16 01:16 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
There are some helpful tips for basic at home rebuilds from a site called Pirate 4X4.
Just google it.
Set-up bearings make the job go much smoother and when you get your parts from doctordiff you will have everything you need the first time. I would upgrade the side gears to the ones Cass sells they are much stronger than the factory 2 piece gears.
Gus beer
64 Plymouth Savoy
Dana 60
