Botched helicoil job #2104940
07/06/16 02:42 PM
07/06/16 02:42 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Well, I figured I would give everyone a good laugh today. I had a stud stripped out on my Torker, and decided I would fix it this weekend so I can get her cruising again before I fool with my disc brake swap. Well, needless to say, I screwed the pooch. When I was drilling out the hole, it got just a little bit cockeyed and now the carb won't fit on the intake . Just lovely. I did get lucky though and picked up a Performer off Summit for 25 bucks off. Anyway, my question is, what to do now about the Torker? Is there a way to fix this that is worthwhile, or do I try to unload it for cheap and let someone with more knowledge than me fix it?
2014 Ram 1500 Pentastar V6
1966 Fury II 4 door
Re: Botched helicoil job [Re: KingTuna] #2104945
07/06/16 02:45 PM
07/06/16 02:45 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Keensert and a drill press so you can drill straight.
http://www.acmeindustrial.com/insert_comparison.html
Don't be the exception.
Re: Botched helicoil job [Re: KingTuna] #2104946
07/06/16 02:46 PM
07/06/16 02:46 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Assuming enough meat, remove the coil and install a threadsert
Re: Botched helicoil job [Re: KingTuna] #2104949
07/06/16 02:53 PM
07/06/16 02:53 PM
Enlarge the hole in the carb so the stud will slide through work twocents
Re: Botched helicoil job [Re: KingTuna] #2104957
07/06/16 02:57 PM
07/06/16 02:57 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I have used this
https://www.waresdirect.com/products/com...R4ANBoC2efw_wcB
to fill holes, redrill and rehelicoil aluminum castings when I used to overhaul satellite antennas in the Navy.
Re: Botched helicoil job [Re: KingTuna] #2104983
07/06/16 03:45 PM
07/06/16 03:45 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Cab, I thought about this but when I started checking it would require removing more material from my new carb than I am comfortable with. Luckily, I was planning on upgrading the intake in the future so it'll be alright.
I will admit, I should have used a drill press, but I was being lazy and trying to take short cuts. I didn't want to have to pull the intake, take it to a friends house 20 minutes away(I don't have a drill press), and then re-assemble and so forth. Lesson learned.
Supercuda, thank you for both of those ideas. I wish I would have known about the keenserts, I probably would have tried those instead of helicoil.
1966 Fury II 4 door
Re: Botched helicoil job [Re: KingTuna] #2105013
07/06/16 04:25 PM
07/06/16 04:25 PM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
run three screws?
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Botched helicoil job [Re: KingTuna] #2105016
07/06/16 04:27 PM
07/06/16 04:27 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
You can buy oversized threaded inserts, but the kits are expensive. I'd just remove the insert and tig the hole closed, then re-drill and tap.
Re: Botched helicoil job [Re: KingTuna] #2105056
07/06/16 05:30 PM
07/06/16 05:30 PM
MA
steve70 Offline
steve70  Offline
MA
Search Durafix. I've used it to repair machined parts that I've had many hours into but made a small mistake. It takes a little practice but it's great for filling holes in aluminum. You can actually fill and then add the correct screw and unscrew it once it cools. There are some videos on their website and YouTube.
1970 Challenger T/A 4 speed
Re: Botched helicoil job [Re: 451Mopar] #2105057
07/06/16 05:34 PM
07/06/16 05:34 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not as expensive as a tig welder.
$2.53 each at Fastenal, uses 1/2-13 tap, common size tap there.
Of course, I doubt an intake has the meat for that big a hole in the carb mounting area.
Re: Botched helicoil job [Re: KingTuna] #2105059
07/06/16 05:36 PM
07/06/16 05:36 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Anyone want to buy a Torker with a botched helicoi?
1966 Fury II 4 door
Re: Botched helicoil job [Re: KingTuna] #2105107
07/06/16 06:58 PM
07/06/16 06:58 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I would devcon the hole shut, drill and retap it. Good to go.
Re: Botched helicoil job [Re: KingTuna] #2105359
07/07/16 12:33 AM
07/07/16 12:33 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
See if you can find an aluminum bolt, drill/tap the screwed up hole oversize, red lock tight it in ,cut off flush and redrill/tap straight this time. I have did it and it worked for me.
Re: Botched helicoil job [Re: KingTuna] #2105522
07/07/16 10:45 AM
07/07/16 10:45 AM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Thank you, I'll look into that. I have the intake off now so repairs will be much easier and a drill press will definitely be used this time.
1966 Fury II 4 door
Re: Botched helicoil job [Re: KingTuna] #2105877
07/07/16 08:43 PM
07/07/16 08:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
A common repair for that kind of thing involves drilling it out, pressing in a tight fitting pin, cutting it flat, and making a new hole.
Since I don't think you have that capacity (most people don't) there is an easy alternative.
If you can go slow, easy, and accurately on a real drill press then drill it out, stuff a Time-sert Big Sert in the hole, and call it done. They were designed for pulled out helicoils and such. I have some but they're in metric sizes.
- Stu Harmon
Re: Botched helicoil job [Re: rowin4] #2106084
07/08/16 04:18 AM
07/08/16 04:18 AM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Winner right here.
Re: Botched helicoil job [Re: KingTuna] #2106174
07/08/16 12:00 PM
07/08/16 12:00 PM
Georgia
K
KingTuna Offline OP
KingTuna  Offline OP
K
Georgia
Thanks for all the replies. I got the Performer installed last night, so this weekend I'll see if I can fix my screw up.
1966 Fury II 4 door
