Page 2 of 3 1 2 3
Re: Sbm Victor head results [Re: B3422W5] #2103961
07/04/16 10:50 PM
07/04/16 10:50 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Did anyone ever say whether these could be used on a 48 degree block. I was offered a deal on an old R block and assembly that is pretty hard to turn down.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Sbm Victor head results [Re: MR_P_BODY] #2104029
07/05/16 01:03 AM
07/05/16 01:03 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Originally Posted By MR_P_BODY
[quote=DARTH V8Я]
If you have to worry about simple headers flanges
you better find a new hobby... you can make them
yourself with a drill and air grinder if you want
wave
Oh please Mike. Find a new hobby? LMAO. Where do you come up with this bullturd?
Thats how I started building headers before I
bought a mill... yeah it took hours to build a
single flange.. but I didnt want to blow the
money for a set
wave
There comes a time in your HP life you have to learn where to draw the line. If header fabrication or having a set built isn't in your range of sight due to personal skills or cost.... maybe you better lower your view. Sounds to me like you are at the W5/chassis headers are readily available stage. I went in over my head and believe me, my fab skills are little to none. Cheap it's not, but if you're going to play.... well, you know the rest. Nice thing about a custom set of headers, well in my case, I can actually remove the headers without even jacking the car up or loosening the engine and they FIT!!!. These E brock heads are aimed a bit higher than your run of the mill small block build.
Re: Sbm Victor head results [Re: J_BODY] #2104035
07/05/16 01:17 AM
07/05/16 01:17 AM
PA.
"Little"John
"Little"John
PA.
Ya and I don't think they would work well with that stock cast iron intake manifold. Lol
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sbm Victor head results [Re: pittsburghracer] #2104046
07/05/16 01:44 AM
07/05/16 01:44 AM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
laugh
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: Sbm Victor head results [Re: DARTH V8Я] #2104048
07/05/16 01:53 AM
07/05/16 01:53 AM
PA.
"Little"John
"Little"John
PA.
laugh
Diet Mountain Dew and vodka just came out of my nose. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sbm Victor head results [Re: pittsburghracer] #2104060
07/05/16 02:34 AM
07/05/16 02:34 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
So what you guys are saying is when I bolt a aftermarket part to a aftermarket part with a aftermarket part I should not be suprised when they don't fit. biggrin
"Just a Bracket car dressed up like a streetcar"
Re: Sbm Victor head results [Re: WHITEDART] #2104067
07/05/16 03:09 AM
07/05/16 03:09 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
waiting for the "why don't they look stock" crowd...... Oh yeah, that's the big block guys laugh2
Re: Sbm Victor head results [Re: Just-a-dart] #2104070
07/05/16 03:17 AM
07/05/16 03:17 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Originally Posted By Just-a-dart
So what you guys are saying is when I bolt an expensive aftermarket part to an expensive aftermarket part with an expensive aftermarket part I should not be suprised when they don't fit. biggrin
Fixed
Re: Sbm Victor head results [Re: J_BODY] #2104076
07/05/16 03:43 AM
07/05/16 03:43 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
There are plenty of them in the small block world too.
Re: Sbm Victor head results [Re: WHITEDART] #2104124
07/05/16 10:18 AM
07/05/16 10:18 AM
CJD AUTOMOTIVE Offline
A Mopar part that needs "massaged" before fitting....now there's a shock. Are all these people bitching about parts not fitting new to Mopar stuff?
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: Sbm Victor head results [Re: WHITEDART] #2104127
07/05/16 10:24 AM
07/05/16 10:24 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The bolt pattern is for sure low for a W2, now I don't know how much wiggle room there is inside an 1 7/8" TTI W2 header, it might just end up at the top of the tube if the exhaust port is smaller than 1 7/8"?
I sure like the looks of these heads but for the cost I can be pretty far down the road on a G3 swap.
68 Barracuda Formula S 340
Re: Sbm Victor head results [Re: WHITEDART] #2104333
07/05/16 05:16 PM
07/05/16 05:16 PM
sst404b Offline
sst404b  Offline
This is a pic of the W2 headers installed. We drilled holes to match heads ,also the header bolts are 3/8.Stainless headers have the flanges made and in stock. And to answer the O P the heads are well worth the money and effort. Ours is in car and running but the converter was cracked around the weld and leaking so we had another one built and it is due in this week. Hope to run the car soon,but it's 100 degrees in Texas and I'm too old to put up with the heat
Ray Buckner
Re: Sbm Victor head results [Re: sst404b] #2104338
07/05/16 05:24 PM
07/05/16 05:24 PM
Mopar
Jason B Offline
Jason B  Offline
Mopar
Ok guys go to stainlessheaders.com or call them at 952-890-9219 and speak with Chris. They have the flanges in stock and are very affordable. I bought a complete Stainless kit flanges, J bends collectors ect... for like 1200.00.
1968 Cuda 440" Edelbrock Victor Head Small Block.
[img]https://board.moparts.org/ubbthreads/upload4/23859.png[/img]
Re: Sbm Victor head results [Re: Jason B] #2104347
07/05/16 05:39 PM
07/05/16 05:39 PM
Tucson, Arizona
clonestocker Offline
Tucson, Arizona
whistling
[img] [/img]
Re: Sbm Victor head results [Re: clonestocker] #2104362
07/05/16 06:05 PM
07/05/16 06:05 PM
PA.
"Little"John
"Little"John
PA.
Ohhhhh my God you had to drill new holes. Send them back for a refund!!!!!!!!!!!!!!!
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sbm Victor head results [Re: sst404b] #2104364
07/05/16 06:08 PM
07/05/16 06:08 PM
PA.
"Little"John
"Little"John
PA.
Ray Buckner
Once again THANKS for providing lots of good info on your build. Its GREAT to see that some of us aren't afraid of a little work. I can't wait to see your track results and good-luck.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Sbm Victor head results [Re: pittsburghracer] #2104399
07/05/16 06:56 PM
07/05/16 06:56 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I thought the same thing. LOL
Re: Sbm Victor head results [Re: pittsburghracer] #2104450
07/05/16 08:14 PM
07/05/16 08:14 PM
Its a TRAP!
DARTH V8Я Offline
DARTH V8Я  Offline
Its a TRAP!
Who's afraid?
Re: Sbm Victor head results [Re: pittsburghracer] #2104523
07/05/16 10:20 PM
07/05/16 10:20 PM
jacksonville,FLORIDA
slammedR/T Offline
slammedR/T  Offline
Nope, so you should let me get that 48* R3 block....... up
2000 Dakota R/T, 408 magnum, 727, Indy heads
1000cfm 4150 carb, 93 octane fuel.
motor; 10.258 @ 132.78
200 shot; 9.262 @ 144.69
racemagnum
Re: Sbm Victor head results [Re: slammedR/T] #2104561
07/05/16 11:24 PM
07/05/16 11:24 PM
PA.
"Little"John
"Little"John
PA.
Its an R block which I guess is the same but different. He took the block and assembly to a machine shop today and may be available if you are interested. PM me your info and I will pass it on to him
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Page 2 of 3 1 2 3
