Proforged Greaseable LCA Pin Kit #2104204
07/05/16 01:20 PM
07/05/16 01:20 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Has anyone successfully used this kit?
It's .73 to the factory .83 on the shaft body and doesn't fit. I can't get a single person on the line from them for a refund or an answer.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2104219
07/05/16 01:43 PM
07/05/16 01:43 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
If it's a simple difference like that it should be easy to fix. I can understand the disappointment with a non-fitting new part.
If your old ones are still serviceable they can likely be drilled for grease fittings.
- Stu Harmon
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2104506
07/05/16 09:59 PM
07/05/16 09:59 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I believe they are made to NOT use the inner shell, the poly bushing rides right on the pin. So the PF pin would have a larger diameter than stock.
Don't be the exception.
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2109652
07/13/16 10:46 PM
07/13/16 10:46 PM
USA
Consulier Offline
Consulier  Offline
USA
Mine stripped out when installed, put the factory stuff back in. Just throw them out.
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2119812
07/28/16 01:48 PM
07/28/16 01:48 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
I have them on my 69 wagon.
Worked just fine, no problems at all.
1969 Satellite Wagon - G3 Hemi Swap Incoming. | 1969 Coronet Post Coupe.
2002 Intrepid ES | 2009 Ram SLT | 2004 300M Special | 2002 300M Pro Am - Hers
Are you a New England Mopar Enthusiast?
Come check out the revived NorthEast Mighty Mopar at www.northeastmightymopar.com
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2120072
07/28/16 07:34 PM
07/28/16 07:34 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Turns out they produced the wrong part with the right part number. They sent the right one and it went on fine. They were a-body spec.
It's on a friends 70 charger getting a full TVS kit. I'm excited to see how the whole package will feel when limited by Radial T/A's.
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2123492
08/02/16 04:21 PM
08/02/16 04:21 PM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
I'm thinking of trying Bergman's Delrin on my Wife's DD on this years teardown service. We've had the Polys in the there for some time and I wasn't liberal enough with the grease when I installed them, so the car is super creaky.
Re: Proforged Greaseable LCA Pin Kit [Re: AlexP] #2124614
08/04/16 03:25 AM
08/04/16 03:25 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
ive been using the firm feel ones with no problems
Re: Proforged Greaseable LCA Pin Kit [Re: 68rrunner] #2127833
08/08/16 01:51 PM
08/08/16 01:51 PM
Massachusetts
Sneke_Eyez Offline
Sneke_Eyez  Offline
Massachusetts
My UCA bushings are super creaky like that even though they're the rubber ones. It's an annoying noise.
Missed getting to chat with you at Carlisle this year, Dan. Might have the wagon there next year.
Re: Proforged Greaseable LCA Pin Kit [Re: 68rrunner] #2127897
08/08/16 02:33 PM
08/08/16 02:33 PM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
I've got some old Prothane units and the FF greaseable pins on mine.
I have a feeling that the car has sat for so long that I'll be replacing bushings soon anyway.
